Developer documentation
This page is main index of documents relating to developer documentation. For user documentation see here.
Development organization and tools
This chapter contains global information that must be read before starting any development on Dolibarr.
- Organization of project
- To be known before starting to develop
- Environment and development tools
- Dependencies and external libraries
- Get or update sources of a development version
Coding rules and best practices
- Prerequisites
- Language and development rules (PHP, SQL, HTML)
- List of tables
- Tree structure of files and classes are available in the doxygen generated documentation
List of modules
Technical documentation on standard business modules is available in each module's developer documentation pages. Choose the appropriate page you are interested in:
- List of standard modules
- List of complementary modules
- Informations for developpers of complementary modules
To develop a new module/addon for GUI
This section describes how to develop a new module changing the Dolibarr user interface. This can be screens, themes, data, its own CSS stylesheet, source code or all of this.
Script development is not included in this section (this is described in the next chapter).
To develop your own module, check the Module development tutorial.
To develop a batch or command line script
This chapter describes how to develop command line scripts to execute tasks in Dolibarr (read, update data...).
Making modifications to the graphical user interface (GUI) is not included in this chapter. See the previous chapter for this.
To develop a script, like a cron script or a command line import tool to import data from an external source, you can have a look at the Script development page.
Technical components of Dolibarr
Tree structure
The path hierarchy of the current version files is available from the doxygen generated documentation (similar to generated "javadoc" documentation).
Paths to use to add new files by a new module are defined in the documentation to develop a new module (see Module development).
Setup storage
There are 3 places for Dolibarr setup parameters.
- Dolibarr technical setup parameters (authentication mode, database logins and storage area for files) are defined in only one setup file:
/conf/conf.php.
- See Configuration file for more information.
- Global features parameters are stored in Table llx_const.
- See the Constants page for more information.
- Feature parameters specific to a user are stored in Table llx_user_param.
Business objects
See Business Objects
Menus system
See Menus system
Tabs system
See Tabs system
Skins system
See Skins
Widget system
See Widget system
Authentication system
See Authentication
Permission system
See Permissions
Translation system
Error management
See Error reporting
Canvas system
Canvas is a developer feature to replace screens to create, update or view a record (products, thirdparties, contacts, ...). For example, you can replace the input form used to create a new third party, or its editing form, or replace its viewing template.
Triggers system
Triggers are a development feature to execute personalized code during a Dolibarr "business event" (creation of an invoice, deleting a user, update of third party, etc...), and only for a business event. To personalize code for other contexts, see the Hooks system chapter instead.
For triggers usage, see this page.
Hooks system
See Hooks system
Variable substitution system
See Variable substitution system
Web services
Dolibarr can be setup to provide some services.
See Module Web Services API REST (developer)
Note: The Module Web Services API SOAP (developer) is deprecated.
Files/Documents storage management
Numbering modules
For each entity created in the application, Dolibarr assigns a reference. In order to adapt the reference to any use, Dolibarr use modules to define the reference generation rule. Several standard modules are supplied. Some are generic and are used to define the numbering mask (number on x characters, with or without prefix, including the date or not, etc.), which can meet most needs. However, there are still cases where the modules provided don't meet the needs. In this case it is necessary to develop a custom numbering module.
For more information, see Create numbering module.
Document templates and documents generation
More documentation about document generation from templates is available to Create a PDF document template or Create an ODT document template.
Extrafields
See Extrafields
Online payment system
Other internal function
There are many internal libraries your code can use. You may find a lot of generic functions in the functions.lib.php, functions2.lib.php or admin.lib.php. Any function found in htdocs/core/lib/*.lib files can be used.
To specify a requirement based on Dolibarr version number
For example, to make a condition based on requiring Dolibarr version > 3.5, you can use versioncompare and versiondolibarrarray found in admin.lib.php:
if (versioncompare(versiondolibarrarray(), array(3,5,0)) > 0)
}Mass exports/imports
Interfaces and links with other applications
Interfaces using API or WebHooks:
- Interfaces Dolibarr toward foreign systems or Dolibarr toward Dolibarr (Dolibarr Triggers, Hooks or WebHooks)
- Interfaces from foreign systems toward Dolibarr (API WebServices)
Integrate Dolibarr to synchronization platforms:
Integrate Dolibarr to automation/no code platforms:
- Integration of Dolibarr to the Zapier automation platform
- Integration of Dolibarr to the n8n automation platform
- Integration of Dolibarr to the Make automation platform
Integrate Dolibarr to ELT/ETL/data integration/no code platforms:
FAQ
All FAQs are available through the FAQ index page FAQ EN
