Developer documentation
Global informations
This chapter contains global informations that must be read before to start any development on Dolibarr.
- Organisation of project
- To known before to start to develop
- Environment and development tools
- Dependencies and external libraries
- Langage and development rules
- Get a version from CVS
Technical setup of Dolibarr
Dolibarr setup (authentication mode, database logins and storage area for files) are defined in only one setup file conf/conf.php. See Configuration file for more information.
Database
List of existing modules
Documentations, for developers, for a standard business modules, are defined on page Modules.
List of other modules is defined on page of Complementary modules
To develop a new module/addon for GUI (new screens)
This section describe how to develop a new module on Dolibarr graphic user interfaces (GUI). A GUI module can contains its own screens, its own data and its own CSS stylesheet. Script development is not included in this section (this is described in next chapter). Numbering modules, modules for documents generation, skins or triggers are also described in other following chapters.
To develop your own GUI extension, go on tutorial: Module development
To develop a batch or command line script
This chapter describe the way to develop its own command line script to realize Dolibarr treatments (read, update data...). Making modifications on user gui interface (GUI) is not included in this chpter. See previous chapter for this.
To develop a script, like a cron script or an command line import tool to import data from an external source, you can have a look at the page: Script development
Setup system
There is 2 area for Dolibarr parameters.
- Global parameters are stored in Table llx_const.
- Parameters for particular users are stored in Table llx_user_param
See page Constants
Menus system
See page Menus system
Skins system
See page Skins
Box system
See page Box system
Authentication system
See page Authentication
Permission system
See page Permissions
Translation system
See page Translation system
Error management
See page Error reporting
Numbering modules
For each entity created in the application, Dolibarr assigns a reference. In order to adapt the reference to any use, Dolibarr use modules to define the rule of generation of this reference. Several modules are supplied with application. Some are generic and are used to define the mask numbering (number on x characters, with or without prefix, including the date or not, etc.), which can meet most needs. However, there are still cases where the modules provided does not meet the need. In this case it is necessary to develop its own numbering module.
For more information, see on page Create numeration module
Les modèles et la géneration de documents
Plus de documentation au sujet de la génération de documents depuis des modèles est disponible sur la page Create document model
Files/Documents storage management
See pagee Generated documents
Mass exports/imports
Interfaces and links with other applications
- Interfaces Dolibarr toward foreign systems (Dolibarr Triggers)
- Interfaces from foreign systems toward Dolibarr
- Web Services
FAQ
All FAQ are available through index page FAQ EN
