Developer documentation
Global informations
This chapter contains global informations that must be read before to start any development on Dolibarr.
  1. Organisation of project
  2. To known before to start to develop
  3. Environment and development tools
  4. Dependencies and external libraries
  5. Langage and development rules
  6. Get a version from CVS
Technical setup of Dolibarr
Dolibarr setup (authentication mode, database logins and storage area for files) are defined in only one setup file conf/conf.php. See Configuration file for more information.
Database
  1. Naming rules
  2. List of tables
  3. Database structure update
List of existing modules
Documentations, for developers, for a standard business modules, are defined on page Modules.
List of other modules is defined on page [1]
To develop a new module/addon for GUI (new screens)
This section describe how to develop a new module on Dolibarr graphic user interfaces (GUI). A GUI module can contains its own screens, its own data and its own CSS stylesheet. Script development is not included in this section (this is described in next chapter). Numbering modules, modules for documents generation, skins or triggers are also described in other following chapters.
To develop you own GUI extension, go on tutorial: Module development
To develop a batch or command line script
Cette section décrit la procédure pour développer son propre script batch afin de réaliser des traitements dans Dolibarr (lecture, eccriture, etc...). La réalisation de modification sur l'interface utilisateur (IHM) ne rentre pas dans ce périmètre. Voir le chapitre précédent pour cela.
Pour développer un script quel qu'il soit, comme un script de traitement cron ou encore un script d'import de données issus d'un autre système, se référer à la page: Script development
Setup system
There is 2 area for Dolibarr parameters.
See page Constants
Menus system
See page Menus system
Skins system
See page Skins
Box system
See page Box system
Authentication system
See page Authentication
Permission system
See page Permissions
Translation system
See page Translation system
Error management
See page Error reporting
Numbering modules
Pour chaque entité crée dans l'application, Dolibarr attribue une référence. Afin de pouvoir adapter cette référence à toute utilisation, Dolibarr utilise des modules pour définir la règle de génération de cette référence. Des modules sont fournis en standard donc certains sont génériques et permettent de définir le masque de numérotation (nombre sur x caractère, avec ou sans prefix, incluant la date ou pas, etc), ce qui permet de répondre à la plupart des besoins. Toutefois, il existe toujours des cas où le module fourni en standard ne répond pas au besoin. Dans ce cas il est nécessaire de développer son propre module de numérotation. Plus d'information sur la page Create numeration module
Les modèles et la géneration de documents
Plus de documentation au sujet de la génération de documents depuis des modèles est disponible sur la page Create document model
Files/Documents storage management
See pagee Generated documents
Mass exports/imports
  1. Mass imports
  2. Mass exports
Interfaces and links with other applications
  1. Interfaces Dolibarr toward foreign systems (Dolibarr Triggers)
  2. Interfaces from foreign systems toward Dolibarr
  3. Web services
FAQ
All FAQ are available through index page FAQ EN
