Installation - Upgrade
Install Dolibarr
On your dedicated computer/server (installation "On Premise")
Logo windows.png Manually or with DoliWamp
- Prerequisite: Windows
This process works only for Windows users and is recommended for user with no computer knowledge. If you have experience with Apache, PHP and Mysql installation, next chapter is better for you.
If you have time and want to learn how to install an Apache, PHP and MariaDB web server, see the Manual installation on Windows page for step-by-step instructions.
However, if you are a newbie user and running Windows, you can use DoliWamp. DoliWamp is a specialized Dolibarr distribution for Windows. This distribution allows you to make an installation under Windows with all prerequisites (Apache, Mysql, PHP) and with no computer knowledge. This is steps to install DoliWamp:
  • Download last Dolibarr version for Windows DoliWamp.
For this, see at Sourceforge mirror
  • Run the downloaded .exe and follow instructions.
Logo ubuntu.png With DoliDeb (Debian or Ubuntu .deb package)
- Prerequisite: Linux Ubuntu
This process works only for Ubuntu or Debian Linux users and is recommended for user with little computer knowledge. If you are experienced with Apache, PHP and Mysql installation, the chapter 'with standard package' is better for you. However, if you are a newbie user and running Ubuntu, you can use DoliDeb. DoliDeb is a specialized Dolibarr distribution for Debian or Ubuntu. This distribution allows you to make an installation under Ubuntu with all prerequisites (Apache, Mysql, PHP) and with no computer knowledge.
Logo rpm.png With DoliRpm (Fedora, Redhat, Mandriva, Mageia or OpenSuse .rpm package)
- Prerequisite: Linux Fedora, Redhat, Mandriva, Mageia or OpenSuse
This process works only for Fedora, Redhat, Mandriva, Mageia or OpenSuse Linux users and is recommended for user with no computer knowledge. If you have experience with Apache, PHP and Mysql installation, next chapter 'with standard package' is better for you. However, if you are a newbie user and running Fedora or Redhat, you can use DoliRpm. DoliRpm is a specialized Dolibarr distribution for Fedora, Redhat or Mandriva. This distribution allows you to make an installation under such OS with all prerequisites (Apache, Mysql, PHP) and with no computer knowledge.
Gnu.png With Dolibarr (standard .zip package or from git)
- Prerequisite: Apache, PHP and a database server (MySQL or PostgreSQL) are already running correctly and user/pass (of a new database or root server) is known.
- Level: Users with few Web and Database administration knowledge.
  • Check that you have installed Apache, PHP 7.1.0+ and a database server (MySQL 5.1+ or PostGreSQL) correctly (check list of installed packaged on your server by using the package manager of your distribution). If not, install them (use last recent version).
  • Check that main root or admin user/password couple for the server is known and works correctly. If this root or admin user/password is not known because not yet defined, read following chapter. Otherwise go on next step:
MySQL or MariaDB database
For Linux users, if you have just installed a MySQL or MariaDB server, the admin user is root. If the root password has never been set yet, you must run the following command to initialize the password:
mysql
Then enter and \q to quit.
To check that the connection with the new couple user/password works, launch the command
mysql -u root -p
And type your password newrootpass then \q to quit if the connection has been successful.
PostgreSQL database
For Linux users, if you have just installed a PostgreSQL server, you must run the following command to initialize an admin user and password. For this, add the following line in file /etc/postgresql/x.x/main/pg_hba.conf (replace x.x with your postgres version)
Also, comment the line
#local   all         all                               ident
This line ensure that system login used to connect to database (it will be login the web server run with), is same than database account (this is never the case).
sudo -s -u postgres
createuser dolibarrowner
psql -U postgres -d template1
alter user dolibarrowner with password 'dolibarrownerpass';
ALTER USER dolibarrowner WITH SUPERUSER;
ALTER USER dolibarrowner WITH CREATEDB;
ALTER USER dolibarrowner WITH CREATEROLE;
\du
exit
Install Web server
  • Go into the directory where to install Dolibarr (the web root directory defined for your web server virtual host. Example of setup of virtual host are available on Webserver this page).
  1. For Debian and Ubuntu families, it is generally: /var/www (newer versions: /var/www/html)
  2. For Mandriva, RedHat, Fedora: /var/www/html
  3. For Suse: /srv/www/htdocs
$ cd /var/www
or
$ cd /var/www/html
  • Get the application archive of last stable version
from zip file
$ wget http://www.dolibarr.org/files/dolibarr.zip
  • Uncompress archive
$ unzip dolibarr.zip
or from git repository
$ git clone --depth 1 -b X.Y http://github.com/Dolibarr/dolibarr.git dolibarr
Replace X.Y with the version you want to get. Remove "--depth 1" if you don't mind downloading the entire history of the project (programmers may find it useful but end users probably won't).
  • Rename directory dolibarr-x.y.z into dolibarr to have a directory name that does not depends on version (replace x.y.z with source version)
$ mv dolibarr-x.y.z dolibarr
  • Change permissions and owner of the 'dolibarr' directory to that of the group under which the web server runs (assumed to be 'www-data' for debian, 'apache' for redhat, mandriva, fedora)
or
  • For Fedora, since SELinux is usually enabled, it is also advisable to run the following commands to make the 'dolibarr' directory compliant with the SELinux requirement (else you are likely to get quite a few alerts) :
  • As a root user, create, into directory dolibarr/htdocs/conf, an empty configuration file called conf.php and set the web server user as owner (for instance www-data on Debian, apache on Mandriva, RedHat, Fedora or other distributions ...). This is required because the web server will have to write into this file during install process.
Note: For Ubuntu no need of htdocs, you just have to make dolibarr root by placing all files and folders of htdocs in /var/www/dolibarr then from browser do <MyIP>/dolibarr/index.php (see this discussion as reference to this addendum [1])
  • As a root user, create a directory that will be used to save all files generated and stocked by Dolibarr (PDf invoices, uploaded images, ...), and attribute to this directory a owner that must be the web server (example www-data on Debian, apache on Mandriva, RedHat, Fedora...). The web server must have write permission into this directory. It is recommended to use a directory outside of your directory of web pages, for example - "/var/lib/dolibarr/documents"
  • Now call your browser to point to the main page
or if you didn't create the htdocs directory
  • Follow instructions of setup steps until end of install process.
  • For security reason, we recommend, once setup is finished, to create a file install.lock into Dolibarr document directory that only root user can delete. This will lock the call of the install process again (you will have to remove this file for upgrades).
If this is not done, Dolibarr will show you a warning once logged by an administrator user.
On a mutualized Web Hosting Provider (without terminal/SSH access)
It is not possible to provide a generic documentation to install Dolibarr on a particular Web hosting provider as this depends on provider. In most cases, using the following process should works for most providers:
- Prerequisite: Apache web server, PHP and a database server (MySQL or PostgreSQL) are already running correctly and user/pass (of a new database or root server) is known.
- Level: Users with few Web and Database administration knowledge. Knowledge to use a tool (FTP, SFTP) to upload files on the server.
  • Check that you have an Apache web server, PHP and a database server (MySQL or PostGreSQL) that works correctly.
Warning.png Warning, check that code page of PHP server and database server are same (utf8 recommended).
  • Check that main root or admin user/password couple for the server is known and works correctly. Ask them to your Web Hosting Provider if unknown.
  • Get the application archive of last stable version and uncompress it locally.
  • Upload all content of htdocs directory to your web root directory, for example using FTP in binary mode.
  • Create a directory called "documents" into Dolibarr directory that will serve to save all documents generated and stocked by Dolibarr (PDF invoices, uploaded images, ...). The web server must have write permission into this directory. You can set permissions with your FTP client.
  • Now call your browser to point to the main page index.php
  • For security reason, we recommend, once setup is finished, to create a file install.lock into Dolibarr installed directory. This will lock the call of the install process again (you will have to remove it for upgrades). If this is not done, Dolibarr will show you a warning once logged as an administrator user.
On a SaaS or Cloud web hosting provider
Dolibarr is also available on a lot of "ready to use" SaaS or Cloud platforms/services that provides preinstalled versions.
See page Cloud Solutions.
Dolibarr can also be installed manually on all Cloud platforms that support PHP and Mysql.
Using Docker
For admins with Docker experience, it is possible to use the docker build files located in the source repo here: https://github.com/Dolibarr/dolibarr/tree/develop/build
git clone https://github.com/Dolibarr/dolibarr/
cd ./dolibarr
git checkout tags/<desiredrelease>
cd build/docker
docker-compose up
Read the README carefully. As of version 12+ it recommends to use the built in docker files for development only, while an outside repo: https://hub.docker.com/r/tuxgasy/dolibarr is recommended for production environments.
First setup
See page Setup.
Setup a LDAP connection
If you want to use a LDAP: See Install and configure OpenLDAP.
Import external data
Upgrade Dolibarr
This chapter describe processes to upgrade an existing installation of Dolibarr from an old version to a new one. The process is the same, whatever version you are coming from and version you are going to, but it will differ according to the distribution/operating system you used for your first installation. You should use the same for upgrade.
Logo windows.png With DoliWamp (Windows .exe package)
  • First make a backup of your current installation
  • Download new .exe package of DoliWamp.
  • Run downloaded .exe file and follow steps without changing any default values. This will upgrades all your files.
  • At the end of the execution, your browser is launched with a page to ask you to run upgrade of your database. Choose the upgrade according to your case.
If there is more than one version late, the page in your browser will loop to start again the upgrade wizard as often as required to run upgrade process, version by version, until your reach the new installed version.
  • Process to upgrade using Debian/Ubuntu package is the same as the install process (see previous chapters), so it is as easy as installing a package.
You can also read page Dolibarr for Ubuntu or Debian.
  • Process to upgrade using rpm package is the same as the install process, so it is as easy as installing a package (see previous chapters).
Gnu.png With Dolibarr (standard .zip package or from Git)
This is tutorial to use when using standard distribution for a manual upgrade.
  • Go into the directory where you installed Dolibarr (it might be the root directory of your web, for example /var/www under Debian)
$ cd /var/www
For installation that used the zip file
  • Get archive of last version
$ wget https://www.dolibarr.org/files/dolibarr.zip
  • Uncompress the archive
  • Copy all new extracted files (the one uncompressed into directory dolibarr-x.y.z) to the directory where you put your old Dolibarr version. This will overwrite old files with new ones without removing files specifics to your installation (like conf.php file or complementary non official installed modules).
  • If no error, you can now remove the directory of source files
$ rm -fr dolibarr-x.y.z
  • Now open your Dolibarr in your browser. It should open automatically the install/
and choose Update in suggested menu.
For installation that used GIT
If you already cloned the repo simply upgrade by checking out a version tag like so:
$ git checkout 13.0
$ git pull origin 13.0
Note:
If you want to script the database upgrade process (to avoid the upgrade process from web browser), you can run the 3 upgrade processes from command line:
$ cd htdocs/install
Note: z must be "0" because only major versions have a migration script to run.
Return code will be 0 if success, 1 if error (if this happens, see file output.html, output2.html or output3.html).
Note: If you have a message that tell the install process is locked by a file, remove the file install.lock stored in Dolibarr root directory.
  • For security reason, once setup is finished, you should create a file install.lock into Dolibarr documents directory. This will lock the call of the install process again (you will have to remove this file for future upgrades). If this is not done, Dolibarr will show you a warning once logged with an administrator user.
