Module Stocks En
Stock
Numéro/ID du module 52
Doc développeur du module Module Stock (developer)
The Stock management module can save status for stocks of products into warehouses and edit/correct quantities of products.
It provides also features like Replenishments and Inventories.
The setup page allows you to choose from four options, when the stock is automatically incremented or decreased (depending on events in the order or invoice business process).
Definition
  • Physical stock is the quantity of products in the warehouses.
  • Virtual stock is the physical stock MINUS the number of products ordered by customers (orders with status validated) PLUS the quantity ordered from suppliers (orders with status "sent to the supplier").
Create a warehouse
The creation of a warehouse is the mandatory first step for stock management. You can create a warehouse on the Products/Services tab, clicking Stocks on the left menu and then New warehouse stock. The only required information is a reference code and a warehouse name, the other fields are optional. You must then set whether the warehouse is active or not (opened / closed). A closed warehouse cannot be used by other Dolibarr functions. This is a good way to prepare a warehouse with stock before you activate it, or to temporarily block stock movements during an inventory.
Allocate product stocks
  • This has to be done from the stock tab on the page of the product, which can be found on the products section of the left menu.
  • You can also do this from the stock tab on the page of the warehouse.
For multiple updates of stock, the import process should be used.
Automatic stock updates
Depending on the module configuration, the stock is updated either at the time of an order, at the time of shipment, at the time of invoice, etc.. A movement of stock is then registered according to the chosen increase/decrease stock option.
Manual stock updates
If you wish to make adjustments to the existing stock amounts (because of internal production, theft, loss, aging, ...), you can do it directly via the stock tab on the page of the product. Use the label field to specify the reason for the change, or to add miscellaneous information.
Inventories
From menu Stocks - Inventories, you will find features to make an inventory. See page Make an inventory for documentation on how to make an inventory.
Warehouse strategy and valuation
It is possible to obtain a detailed list of products and movements in a specific warehouse by clicking on the name from the list of warehouses.
Removal strategy
When using stock decrease on shipments, a removal strategy is a removal rule to decide which lot/batch/serial, or from which warehouse you take a product when you are doing a shipment.
  • FIFO: First in, first out
  • LIFO: Last in, last out
  • FEFO: First expiry, first out
Currently, Dolibarr does not suggest any product lot or warehouse by priority when you ship a product. You choose from the interface which product/lot quantity, from which warehouse you use. So the removal strategy is a manual selection by the user. You can choose according to FIFO, LIFO, or FEFO, at each shipment.
In a future, a removal strategy may be implemented so the application will use a default choice to suggest the lot/serial/warehouse/qty to match a default removal strategy rule.
Stock valuation
With Dolibarr, you can get a valuation of stock in two ways:
  • Standard valuation: Current price of product * qty in stock
  • Average Weight Price (AWP): AWP of product * qty in stock
Related videos
