Module Eco Tax WEEE
Revision as of 14:46, 17 November 2020 by Eldy (talk | contribs)
Module name Eco Tax WEEE
Last update date / Date mise à jour fiche / Fecha última actualización 2020-11-17
This module allow you to manage eco tax WEEE:
  • Can define amount of the WEEE tax for each predefined product.
  • When you add a product into invoice, order or proposal, a line is automatically added with amount of eco tax (if product has an eco tax weee defined for it).
  • Can export list of all invoices lines / amount of ecotax weee you used.
From the application
Manually
unzip modulefile.zip
Once on setup tab, just choose if you want to have the automatic weee line added on
  • customer proposals
  • customer orders
  • customer invoices
or any combination of them.
Also, in some countries (for example France), you must add an annex page into your PDF to provide list of unit amount for each category of eco tax. Starting from Dolibarr 3.6, just fill the area "Content of new page to add" with content your want to have into this annex page. This page will be added into generated PDF if there is at least one weee tax line. Keep this field empty if you don't want to add annex page.
Example: Screenshot of module setup page (click to enlarge)
  With Dolibarr 3.4+, the field to store Eco tax is not available by default onto product card, so you must define it manually: Go into menu Home - Setup - Modules - Products - Complementary attributes and add the field with label "Eco tax", code "ecotaxdeee" and format "float".
