Module easy dashboard
| Module name | Easy Dashboard |
| Editor / Editeur | Florian DUFOURG - demo |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2019-11-9 |
| Note / Nota |
This module is a simple dashboard that shows some of the most importante informations to manage your business (turnover, expenses, fixed costs, variable costs and profit).
2 graphs show the most important customers (depending of the turnover) and the most important costs.
The end of the dashboard shows important informations of the company (total turnover, categories of costs, current orders...)
How it works
Turnover
The turnover is calculated as the sum of the customer invoices of the period. If an invoice is paid or not does not change how it calculate it.
The graph shows the sum of turnovers (blue line) and the turnover month by month (blue bar)
Spending
Depending on the projects linked with the spending, it is possible to separate fixed costs and variable costs. You will choose between fixed costs and variables costs on the module setup costs (see chapter "SETUP").
This module does not considere : Donations and multicurrency
This module work with the multi company module.
Module Configuration
Configure the module : Before to use the dashboard you should setup the module on the module setup page. There is 2 modes named simple display and advanced display. The simple display mode does not make difference between Fixed costs and variable costs. The module considere to be a fixed cost all the costs (vendor invoices, salaries, tax and loans) that do not have a project. You can also define a specific project for all the fixed costs on the setup page of the module.
Menu
