Script rebuild merge pdf.php
Revision as of 15:06, 9 November 2009 by Eldy (talk | contribs) (Created page with 'Category:Mailing Category:Scripts = Feature/Fonction/Funcionalidad = {{Flag en}} This script is used to build one PDF that contains several PDF. {{Flag fr}} Ce script fa...')
En verysmall.png This script is used to build one PDF that contains several PDF.
Fr verysmall.png Ce script fabrique un fichier PDF à partir d'autres fichiers PDF.
Es verysmall.png ...
Localisation/Localización
  • /dolibarr/htdocs/scripts/invoices/rebuild_merge_pdf.php
Syntax/Syntaxe/Sintaxis
To build/merge PDF for invoices with at least one payment in a date range:
Usage:   rebuild_merge_pdf.php filter=payments dateafter datebefore [lang=langcode]
To build/merge PDF for invoices ina date range:
Usage:   rebuild_merge_pdf.php filter=date dateafter datebefore [lang=langcode]
To build/merge PDF for all invoices, use filter=all
Usage:   rebuild_merge_pdf.php filter=all
To build/merge PDF for invoices with no payments, use filter=nopayment
Usage:   rebuild_merge_pdf.php filter=nopayment
Example: rebuild_merge_pdf.php filter=payments 20080101 20081231 lang=fr_FR
Example: rebuild_merge_pdf.php filter=all lang=it_IT
Tables used/Tables utilisées/Tablas utilizadas
