Table llx facture fourn
Content/Contenu/Contenido
En verysmall.png Contains invoices sent by providers. A provider invoice can be linked to a provider order (Table llx_commande_fournisseur) by the Table llx_element_element.
Fr verysmall.png Cette table contient la liste des factures émises par les fournisseurs. Une facture fournisseur peut être liée à une commande fournisseur (Table llx_commande_fournisseur) au travers de la Table llx_element_element
Es verysmall.png Contiene las facturas emitidas por los proveedores. Una factura de proveedor puede estar enlazada con un pedido a proveedor (Table llx_commande_fournisseur) a traves de la Table llx_element_element.
Structure
rowid int(11)   PRI NULL auto_increment technical index
entity int(11)   1 multi company id
facnumber varchar(50) NO MUL invoice number
type smallint(6) NO 0 type of invoice
fk_soc int(11) NO MUL ID society (llx_societe->rowid)
datec datetime YES NULL creation date
datef date YES NULL date of invoice
tms timestamp NO CURRENT_TIMESTAMP last update date
libelle varchar(255) YES NULL label
paye smallint(6) NO 0 1 if the invoice is payed, 0 otherwise
amount double(16,8) NO 0.00000000 amount
remise double(16,8) YES 0.00000000
tva double(16,8) YES 0.00000000
total double(16,8) YES 0.00000000 total amount
total_ht double(16,8) YES 0.00000000 total amount excluding VAT
total_tva double(16,8) YES 0.00000000 total amount of VAT
total_ttc double(16,8) YES 0.00000000 total amount with VAT
fk_statut smallint(6) NO 0 0= brouillon, 1=impayée, 2=payée, 3=abandonnée
fk_user_author int(11) YES MUL NULL ID of user author of invoice (llx_user->rowid)
fk_user_valid int(11) YES MUL NULL ID of user validator of invoice (llx_user->rowid)
fk_projet int(11) YES MUL NULL ID of related proyect (llx_projet->rowid)
fk_cond_reglement int(11) NO 1 Id of payment condition (llx_cond_reglement->rowid)
date_lim_reglement date YES MUL NULL date limit for payment
note text YES NULL comentary
note_public text YES NULL public comentary
import_key varchar(14) YES NULL import key
En verysmall.png Attention, if the status is 1 (unpayed) but the field "paye" is also 1 (payed), which should never happen under normal use, the invoice is specified payed.
Fr verysmall.png Attention, si le statut est à 1 (impayée) mais le champ "paye" est à 1 également (payée), ce qui ne devrait jamais arriver dans des conditions normales d'utilisation, la facture est indiquée comme payée.
Es verysmall.png Atención, si el statut está a 1 (impagada) pero el campo "paye" está a 1 también (pagada), cosa que nunca pasa en condiciones normales de uso, la factura se indicará como pagada.
