Module Place
Place | |
Numéro/ID du module | 110110 |
Doc développeur du module | Module Place (developer) |
Module name | Place |
Editor / Editeur | Librethic (librethic.io) - Project page on Librethic forge |
Download or buy page / Page achat ou téléchargement | https://www.dolistore.com/fr/modules/1033-Module-Place.html |
Prerequisites / Prérequis | Dolibarr min version 3.1 |
Last update date / Date mise à jour fiche / Fecha última actualización | 2019-07-23 |
Note / Nota |
Add locations, buildings, floors and rooms within Dolibarr ERP/CRM. Can add locations and rooms as a resource to an action from agenda.
- Install module into the custom folder of Dolibarr:
- Upload the file. Note: If it fails, you can manually unzip the file into the custom directory from command line: Go into the *custom* directory and uncompress file with command unzip modulefile.zip
- Module is ready to be activated and used.
If a cog icon appears at end of line of the module, click on it to access the setup page specific to the module.
