Module Capcompta
Revision as of 22:23, 27 October 2026 by Eric.seigne (talk | contribs) (Capcompta 1.3.0)
Information
Module name Capcompta
Editor / Editeur CAP-REL - www.cap-rel.fr
Prerequisites / Prérequis Double-entry accounting and SmartAuth modules enabled
Last update date / Date mise à jour fiche / Fecha última actualización 2026-10-27
Note / Nota Prototype of an expert interface for accountants: binding, journals, ledger and lettering, miscellaneous entries, bank reconciliation, FEC exports and year-end closing, entirely on the keyboard, on top of the native accounting module.
capcompta is built for accountants. It shows that an interface as expert as the one of dedicated accounting firm software can live natively in Dolibarr: everything on the keyboard, dense grids, no page reload, and the Dolibarr accounting engine intact, with its tables and its permissions. It is a prototype in the sense that it is built with the people who use it: it already covers the complete accounting cycle, and your feedback as an accountant shapes the next versions.
At a glance
  • For whom: the person who actually keeps the books, several hours a day in the same screens, and the firms that support them.
  • What the module does: it replaces the accounting screens of Dolibarr with a keyboard workspace, and leaves every accounting calculation to the native engine.
  • What it does not do: neither tax return forms nor intermediate management balances, and it does not replace the accountant: it prepares a clean FEC and reads back the one returned to you.
Feature list
  • Guided setup - check of the chart of accounts, journals, default accounts and fiscal year, with the action that fixes each gap.
  • Binding of sales, purchases and expense reports - account proposed by the Dolibarr engine, accepted with one key or replaced by typing its number, assignment of a whole selection, remembered on the product or the third party.
  • Journals and transfer - preview of each journal, blocking documents named, transfer protected against double writing.
  • General ledger and trial balance - running balance, account and amount filters, general and subsidiary trial balance grouped by class.
  • Lettering - full, partial and automatic, in a panel next to the ledger.
  • Miscellaneous entries - a batch typed in a grid, counterpart proposed, balance checked, draft kept.
  • Bank reconciliation - ticking against the statement, reconciled balance always on screen.
  • Financial statements - income statement and balance sheet by main headings.
  • FEC exports - with an optional archive of supporting documents named after their entry number.
  • Reconciliation of the accountant's FEC - added, changed or removed lines, and added movements written with one key.
  • Year-end closing - prior checks, result entry and opening entries.
  • Takeover of an existing file - opening trial balance pasted from a spreadsheet, missing accounts created in one go.
Screenshots
Links
Requirements
  • Dolibarr 18, PHP 7.4 or newer.
  • Double-entry accounting module enabled: capcompta is an interface to it, not a replacement.
  • SmartAuth module enabled, for the authentication of the interface.
  • A workstation with a keyboard and a wide screen: capcompta is not designed for phones or touch screens.
Update
  1. Install the new version through Home > Setup > Modules/Applications > Deploy/Install external module.
  2. Disable then enable the module again when the release notes of the version ask for it: this declares the new functions of the interface.
Accounting entries and settings are not touched.
Uninstall
Disable the module from Home > Setup > Modules/Applications. capcompta creates no table: every entry stays in the native accounting of Dolibarr.
The workspace opens on the Setup screen as long as the accounting is not ready: chart of accounts, journals, default accounts and current fiscal year. Accounting settings stay those of the native module. The page Home > Setup > Modules > capcompta only holds interface options and the optional connection to the Bernard suggestion service.
Demonstration data
The Demonstration page of the module generates, then purges, two fiscal years of a consulting firm of some fifty employees run through every native journal, with a guided tour of each screen. It is meant for a test or presentation instance: generation is only allowed on a development instance or one declared as a demonstration instance.
Permissions
capcompta declares no permission of its own: it relies entirely on the permissions of the double-entry accounting module, and opens to nobody what the native module would refuse.
The capcompta menu opens the workspace. Every screen is driven from the keyboard and shows its shortcuts in its footer; the working period is shared by all screens. Each screen is described in the documentation.
FAQ
The capcompta menu does not appear.
Check, in this order, that the capcompta module is enabled, that the double-entry accounting module is enabled too, and that the user holds at least one read permission on accounting.
After an update, an action answers "access denied".
Disable then enable capcompta again: this refreshes the declaration of the interface calls. Your data is not touched.
All questions: documentation FAQ.
Developments and improvements can be proposed to the project leader by email (see the headers of the source files) or through the support form.
