Module CapTODO
Revision as of 21:18, 27 October 2026 by Eric.seigne (talk | contribs) (CapTODO 2.0.8)
Information
Module name CapTODO
Editor / Editeur CAP-REL - www.cap-rel.fr
Prerequisites / Prérequis Projects, Third parties, Tags/Categories and Agenda modules; SmartAuth module for the mobile app
Last update date / Date mise à jour fiche / Fecha última actualización 2026-10-27
Note / Nota Simple to-do lists built on the Dolibarr projects and tasks, with a mobile app you install on phones and tablets.
Dolibarr projects and tasks are powerful, but heavy for "call this customer back" or "order the parts". CapTODO turns them into to-do lists: a project category marks the lists, and each task takes one line, from Dolibarr or from your phone.
At a glance
  • Who it is for: teams that track their actions in Dolibarr, technicians and sales people on the road, managers who want to see where the team stands.
  • What the module does: it uses the native Dolibarr projects and tasks; a CapTODO task is a real Dolibarr task, visible in the Projects module, with its time spent and its documents.
  • What it does not do: it keeps no separate task database and sends none of your data to an outside service. The mobile app talks to your own Dolibarr.
Feature list
  • To-do lists - the projects of a configurable category become lists; sorted on five priority levels, changed with arrows or drag and drop.
  • Tasks - due date, priority, linked third party, assignment, subtasks, activity history and recurrence (daily, weekly, monthly, yearly).
  • Attached documents - quotes, plans or site photos on a list or a task, from Dolibarr or by taking a photo with the phone.
  • Tags - colored categories on tasks and lists, created on the fly.
  • Quick entry - one line is enough: #tag, !priority and @task are recognized, voice dictation included.
  • Dashboard - your tasks of the day, of the week and overdue; a manager view shows the whole team.
  • Time log - write down what you do during the day, then link the entries to tasks; usable offline.
  • Agenda - tasks synchronized with the Dolibarr agenda, one colored event type per priority level.
  • Internal messages - messages linked to a task or a list, sent to a user or a group, with a reply thread.
  • Mobile app - installable web app (PWA) on Android and iOS, with a layout made for tablets.
  • Seven languages - French, English, German, Spanish, Italian, Dutch and Portuguese (Brazil).
Screenshots
Links
Requirements
Item Version or condition
Dolibarr 18.0 or later
PHP 7.4 or later
Dolibarr modules Projects, Third parties, Tags/Categories and Agenda, enabled
Mobile app SmartAuth module by CAP-REL, installed and enabled; the CapTODO pages in Dolibarr work without it
Rights an administrator account to install, enable and set up the module
Upgrade
  1. Install the new version through Home > Setup > Modules/Applications > Deploy/install external app/module.
  2. Disable then enable the module again: enabling applies the database updates, creates the new agenda event types and reloads the routes of the mobile app.
  3. On phones and tablets, open the mobile app again so it loads its new version.
Your lists, tasks, settings and time log entries are kept.
Uninstall
Disable the module from Home > Setup > Modules/Applications. Lists and tasks stay ordinary Dolibarr projects and tasks: you still find them in the Projects module.
The setup page is Home > Setup > Modules > CapTODO, tab Settings.
Setting Purpose
Project category for to-do lists the project category that marks the to-do lists; required for the module to work
Default references numbering prefixes of lists and tasks, for example TODO-
Interface keep the Dolibarr menus on the CapTODO pages or show a full screen interface; rich editor for descriptions
Quick actions four buttons per task: send an email, an internal message or add an appointment
Agenda synchronization automatic creation and update of events, event type by priority
Logbook time log activation, default duration, purge of linked entries, dictation trigger words
Permissions
Permission Purpose
Read TODO lists, tasks, messages and the time log access to the module pages and to the mobile app
Create and update TODO lists, tasks, messages and the time log entry and update
Delete TODO lists, tasks, messages and time log entries deletion
Manager view see all team tasks on the dashboard
The rights of the Projects module apply on top: a user sees the tasks of a private project only as a contact of that project or with the right to read all projects.
Once enabled, a TodoList entry appears in the left menu of Projects, with its Messages sub-entry and, when enabled, Logbook for the time log. A CapTODO tab is also added to the third party card, with the tasks linked to that third party.
For the mobile app, open its address on the phone and add it to the home screen; you sign in with your Dolibarr account.
Every screen is described in the user guide (in French).
FAQ
The module is enabled but no to-do list shows up.
Pick the project category of the lists in the module setup, then give that category to the projects concerned.
No agenda event is created for my tasks.
Enable the agenda synchronization in the setup, and tick the synchronization on the task when the automatic synchronization is off.
Do the "Day" and "Week" views follow my time zone?
No: due dates are dates without time, counted in days of the Dolibarr server.
All questions: FAQ of the documentation (in French).
Developments and improvements can be proposed to the project leader by email (see the headers of the source files) or through the support form.
