Module CapComments
Information
| Module name | CapComments |
| Editor / Editeur | CAP-REL - www.cap-rel.fr |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2026-10-25 |
| Note / Nota | Threaded comments on Dolibarr cards, with @colleague mentions, scheduled reminders and notifications that follow the rights of each user. |
Discussions about a customer, a proposal or a project get lost in emails and chat tools. CapComments brings them back where the file lives: a Comments tab on Dolibarr cards, with threads, mentions, reminders and notifications.
At a glance
- For whom: any team working together on the same third parties, proposals, orders, projects or tickets.
- What the module does: it adds a comment thread on each supported card, notifies the colleagues mentioned and schedules reminders.
- What it does not do: it sends no email, changes no business document and never shows a comment to someone who may not open the card.
Feature list
- Comments tab on more than twenty kinds of cards: third parties, proposals, orders, invoices, supplier orders and invoices, projects, tasks, tickets, contracts, interventions, products, expense reports, leaves, manufacturing orders and more.
- Threads with nested replies.
- Mentions with @login, names suggested while typing; a mention only notifies colleagues who may open the card.
- Scheduled reminders at a given date, sent by the scheduled job of the module, and personal reminders with @me, @moi or @self.
- Notifications by a bell in the top bar or by a sticky note, as you prefer.
- Private comments for internal users only, or public ones, also shown to the external accounts of the third party.
- Lists of all comments and of your notifications, filtered by author, third party, message or date.
- Widget of the connected users on the dashboard.
- Demonstration data built and removed in one click, on demonstration and development instances.
- Nine languages: French, English, German, Spanish, Italian, Dutch, Polish, Portuguese and Brazilian Portuguese.
Screenshots
Links
- Module documentation
- What's new in version 1.0.28 (in French)
- Get update notifications
- Support form
- Online demo: a Dolibarr with threads, mentions and reminders already in place, created for you in less than 20 seconds and removed after the session
Requirements
| Item | Version or condition |
| Dolibarr | 18.0 or later |
| PHP | 7.4 or later |
| Rights | an administrator account to install, enable and set up the module |
The Comments tab shows on the cards of the enabled Dolibarr modules: a missing module simply has no tab.
Upgrade
- Install the new version through Home > Setup > Modules/Applications > Deploy/install external app/module.
- Disable then enable the module again: enabling applies the database upgrades and grants the read and write rights to internal users once.
Your comments, notifications and settings are kept.
Uninstall
Disable the module from Home > Setup > Modules/Applications. Comments and notifications stay in the database: enabling the module again later finds them back.
The setup is in Home > Setup > Modules > CapComments. It has the Settings, Demonstration data and About tabs.
| Setting | Role |
| CapComments main menu | shows the menu of the module in the top bar |
| Menu in Tools | adds the menu of the module to the Tools menu |
| Notification style | bell in the top bar, or sliding sticky note |
Scheduled reminders are sent by the CapComments scheduled job: check that it is enabled in Home > Admin tools > Scheduled jobs.
Demonstration data
The Demonstration data tab builds, then purges, a full data set: third parties, a proposal, a project, demonstration accounts, threads, mentions and reminders. It only runs on a demonstration or development instance; elsewhere, set the CAPCOMMENTS_ALLOW_DEMO_DATA constant to 1, or MAIN_FEATURES_LEVEL to 2. Never run it on a production install.
Permissions
| Permission | What it allows |
| Read comments and notifications | see the Comments tab, the comments list and one's notifications |
| Write comments | comment, reply and delete one's own comments |
| Delete comments written by other users | moderate the comments of a card |
The rights of the module add to those of the card: a sales representative limited to their customers only sees the comments of their customers. External accounts only see the public comments of their own third party's cards.
Open a card, click the Comments tab, write your message and tick Private if only internal users should read it. Type @ to mention a colleague, pick a date to schedule a reminder, and send with the button or with Ctrl+Enter. The Reply link opens a reply in the thread.
Your notifications show in the top bar; the full list and the list of all comments are in the menu of the module.
Details are in the user guide (in French).
FAQ
I do not see the Comments tab on a card.
Check that you have the right to read comments and that the kind of card is supported.
A mentioned colleague got no notification.
A mention only notifies people who have the right to read comments and to open the card; a private comment never notifies an external account.
A scheduled reminder was not sent.
Check that the CapComments scheduled job is enabled.
All questions: FAQ of the documentation (in French).
Developments and improvements can be suggested to the project maintainer by email (see the headers of the source files) or through the support form.
