Module PDF Protect
Revision as of 00:39, 2 October 2026 by Theopequiii (talk | contribs) (Fix interlanguage links (English page is the source))
Editor Theo Pequignot (theopequignot.fr)
Module ID 194156
Version 5.12.0
Dolibarr 14 to 24
Where to get it DoliStore
Support contact@theopequignot.fr
A quote sent as a PDF can be copied, edited and sent back under another name. PDF Protect automatically locks quote and invoice PDFs as soon as Dolibarr generates them.
What it does
  • Automatic protection on every PDF generation, for quotes, invoices or both.
  • Opens freely by default: your customer opens the document with a double-click, but editing, extraction and assembly are blocked. Printing and text copying are allowed or not, your choice.
  • Optional opening password: the PDF is then truly encrypted and unreadable without it.
  • Works with online signature: your customer can sign the protected quote online, then both the original and the signed PDF are protected again.
  • Works with bulk merge: the "Generate document" bulk action on quote and invoice lists keeps working.
  • Audit log of every protected document, built-in settings page.
Nothing to install on the server
The built-in engine (AES-256) runs everywhere, including the official Dolibarr Docker image. If your server has qpdf, pikepdf, GhostScript or pypdf, the module can use them too.
Good to know
  • Without an opening password, copy and edit restrictions are honored by common readers (Adobe Acrobat, Foxit…), but a specialised tool can remove them. For real confidentiality, set an opening password.
  • Factur-X PDFs (with an embedded XML file) are protected with qpdf or pikepdf; with the built-in engine they are left as they are so the XML is not lost.
  • An encrypted PDF is no longer PDF/A compliant.
Home → Setup → Modules → "Deploy/install external app/module", upload the zip, enable PDF Protect and tick the documents to protect.
Upgrading from a previous version: replace the files, then disable and re-enable the module (Setup → Modules). Settings, data and user permissions are kept.
Compatibility
  • Dolibarr 14 to 24 (verified on 16, 23 and 24, including Docker).
  • PHP 7.4 to 8.4, MySQL / MariaDB.
  • English and French included. Email support and updates for 2 years.
Screenshots
Support
Questions before buying, installation or update issues: write to contact@theopequignot.fr. I am the developer of this module and I answer myself. Support and updates are included for 2 years with the DoliStore purchase.
