开发环境与工具
Revision as of 09:45, 2 April 2025 by Eldy (talk | contribs) (→‎浏览器 (Chrome / Firefox) + 插件)
您可以使用任何开发环境。但是,这里有一份高度推荐使用的工具清单,因为它们提供了较好的完整性、开发质量和开发效率。Dolibarr的大多数核心开发人员都在使用它们。请注意,所有这些解决方案都是免费和开源的。
Eclipsephp.jpg 适用于每个开发者
这是推荐的基本开发环境,但任何符合Web、PHP和MySQL标准的工具都可以做到这一点。
一个 AMP 服务器
  • AMP 表示 Apache + MariaDB + PHP
Linux平台:默认情况下,这3个产品在所有发行版中都可用。
Windows平台: 安装 [1] (基于MariaDB SQL database、Apache和PHP的组合软件包) 。这个WAMP服务器提供了MariaDB+Apache+PHP三个组件,只需单击一下即可变更其中任何一个组件的版本。
  • Chrome + plugins
You can download Chrome from https://www.chrome.com
  • Firefox + plugins:
You can download this on web site https://www.firefox.com
or the new Firefox Developer Edition: https://www.mozilla.org/de/firefox/developer/
访问数据库的工具(SquirrelSQL 或 DBeaver)
  • SquirrelSQL or DBeaver for database administration.
Go on official web site of this product to download them.
IDE(Eclipse、VSCode)和插件
Eclipse
Install Eclipse
We recommend to use an Eclipse version provided on eclipse.org. For example: https://eclipse.org/pdt/
Also any version available on Eclipse web site is possible.
Once Eclipse is installed, it is recommanded to setup following parameters:
  • Window - Preferences - General - Workspace - Text file encoding -> UTF8
  • Window - Preferences - General - Workspace - New text file line delimiter -> Unix
  • Window - Preferences - General - Compare/Patch - Ignore white spaces -> Yes
  • Window - Preferences - General - Editor - Text editors - Tab delimiter length -> 4
  • Window - Preferences - General - Editor - Text editors - Insert spaces for tab -> No
  • Window - Preferences - General - Editor - File Association -> Add *.lang associated to "Text Editor"
  • Note: You can also disable Windows - Preferences - Java - Editor - Content Assist - Auto Activation
And if PDT is installed (see later):
  • Window - Preferences - PHP - Code Style - Formatter - Tab policy -> Tab
  • Window - Preferences - PHP - Code Style - Formatter - Default indentation for wrapped line -> 1
  • Window - Preferences - PHP - Code Style - Formatter - Default indentation for array initializer -> 0
  • Window - Preferences - PHP - Editor - Typing - Uncheck "When Pasting Adjust Indentation" (keeping this option checked create corruption of text files by adding bad end of line characters)
  • Window - Preferences - PHP - Code Style - Formatter - Use the profile provided into dev/setup/eclipse/PSR-12 [built-in].xml as Eclipse syntax formatter.
  • Note: You can also disable Windows - Preferences - PHP - Editor - Content Assist - Auto Activation
Install plugin Eclipse for PHP: PDT.
If you installed Eclipse version and PDT is not included, all you have to do is using process Help -> Install new software -> Add -> Archive to add module:
Once installed, you must also setup PDT into Eclipse as explained into chapter Environment_and_development_tools_-_Optionnal_components#From_Eclipse
Setup Eclipse to get sources
Once Eclipse is installed, you can connect to GIT repository to get last development version.
For this see page FAQ Get,update GIT project sources.
VSCode
Voir les instructions d'installation de l'éditeur.
Git 钩子
安裝預提交 git hook
您可以使用 git hooks 檢查您提交的文件的語法,並在發生錯誤時取消(或更好地自動修復)提交。
此文件中提供了安裝此類預提交掛鉤的說明:
https://github.com/Dolibarr/dolibarr/tree/develop/dev/setup/pre-commit
此類掛鉤在命令列上使用時可以工作,但在使用通用 IDE 提交時也可以工作(它已通過 Eclipse 和 VSC 進行了驗證)。
安裝後,該掛鉤將在您下一次提交時啟動以重新格式化您的程式碼,因此您的程式碼將始終符合編碼語法規則。如果每個人都啟用此鉤子,則每個人都將使用相同的編碼語法規則,因此強烈建議您盡可能啟用它。如果語法有問題,提交將立即取消。如果它可以自動修復,在安裝預提交掛鉤期間安裝的 phpcbf 將修復它,因此您只需再次嘗試提交即可驗證它。
Computer.png 可选组件
您还可以安装可选组件以获得更多技术支持。请参阅:开发环境与工具 - 可选组件
