Module BilledOnOrders
| Module name | BilledOnOrders |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2025-02-24 |
| Note / Nota |
The module add columns into the list of orders to show the amount billed for each order and the remain to bill. The amount visible is total of all invoices linked to the order. Note: Values added by this module will be useless if you make one invoice for several orders. But if you make one invoice for each order, it will save you time to see, in one page, list of orders and remain to bill.
Once module has been activated, go on page to list orders. New columns are available (Amount billed without tax, Amount billed with tax, Already billed, Remain to pay on billed).
Example: Screenshot with the amount billed without tax, the already billed and remain to pay.
