Module EMailing
Revision as of 10:20, 23 January 2025 by Isamuse (talk | contribs) (→‎Setup: un ajout sur la configuration possible via "other setup")
Mailing
Numero/ID of module 22
Check also that Dolibarr setup to send mails is ok: Setup EMails
Check also the setup options available in Setup Other, for the emailing module. Amongst others, you can set the number of emails to be send for your web interface with MAILING_LIMIT_SENDBYWEB.
Warning.png Note: If a constant MAILING_NO_USING_PHPMAIL is set to 1 in Home - Setup - Other, it is only possible to send emailing when the send mode in setup is not on "PHP Mail" but on another mode (like "SMTPs").
Mass E-Mailing features are available from menus (if Module EMailing has been activated). Menu link can be found in menu "Tools" with default menu manager "Eldy".
Life cycle / Business rules
The full process is this one:
  • the web application screen. In such a case, there is a limit in number of emails sent in one step, 50 by defaut in most cases. If you have more than 50 recipients, you can submit the emailing from screen a second time and the application will automatically send emails to the 50 next recipients. Repeat until all recipients are addressed.
  • or from the command line with script Script mailing-send.php.
Only an emailing with the status Validated can be sent by the script. See page Script mailing-send.php for more information on how to launch it from command line.
