Dolibarr for Mandriva or Mageia (rpm package)
Revision as of 14:54, 19 January 2025 by Eldy (talk | contribs)
For a packaged version for Redhat or Fedora, see Dolibarr for Redhat or Fedora (rpm package).
For a packaged version for OpenSuse, see Dolibarr for OpenSuse (rpm package).
For a packaged version for Ubuntu or Debian, see Dolibarr for Ubuntu or Debian.
Dolibarr for Mandriva or Mageia is a version of Dolibarr ERP/CRM, packaged with Mysql, PHP and Apache with an automatic installer for Mandriva or Mageia users that don't have any technical knowledge.
In a few seconds, after installing this package, you are able to work on Dolibarr, even if you don't have already a web server or if you don't know what is Apache, Mysql or PHP. Everything is installed for you.
It's an "all in one" package that can be downloaded from page https://www.dolibarr.org/downloads/. You will find it into the category "stable versions".
For install, you can click on the dolibarr.x.y.z.rpm file if you use the file manager, or inside a terminal console type:
$ urpmi dolibarr.x.y.z.rpm
where x.y.z is the dolibarr version, ex. dolibarr.2.8.0.rpm
