Module MultiCompany
Revision as of 12:58, 9 January 2025 by Hregis (talk | contribs)
Module name MultiCompany
Editor / Editeur Régis Houssin (iNodbox) - https://www.inodbox.com/
Download or buy page / Page achat ou téléchargement External module - https://www.dolistore.com/product.php?id=1619
Last update date / Date mise à jour fiche / Fecha última actualización 2025-01-9
With this module, Dolibarr is able to manage several instances with only one installation (one unzipping and one database)
See This page
