Module Membership management
Revision as of 14:54, 11 December 2024 by Udo.tamm (talk | contribs) (→‎Membership instalment payment)
Foundations
Numero/ID of module 310
  • Reporting.
Creation of a member type
Creation of personalized attributes
Diagramme d'états d'un adhérent
New or renew a subscription
Take the case of a membership paid for in three instalments. Ask your member for three cheques, the sum of which is equal to the subscription they owe. Then, for dolibarr, the principle is the same as above.
Once you have clicked on New membership, enter the counterparty corresponding to the first cheque, and specify the period of validity, in our case this corresponds to 1/3 of the year. Then, in the Label field, enter Membership Year 1/3, for example. Then click on Add membership. Repeat the operation twice more, adjusting the values to cover the whole year.
Revoke a member
Related videos
