Module EMailing
| Mailing | |
| Numero/ID of module | 22 |
| Developer doc. of module | Module EMailing (developer) |
Check also that Dolibarr setup to send mails is ok: Setup EMails
Note: If a constant MAILING_NO_USING_PHPMAIL is set to 1 in Home - Setup - Other, it is only possible to send emailing when the send mode in setup is not on "PHP Mail" but on another mode (like "SMTPs").
Mass E-Mailing features are available from menus (if Module EMailing has been activated). Menu link can be found in menu "Tools" with default menu manager "Eldy".
Life cycle / Business rules
The full process is this one:
- the web application screen. In such a case, there is a limit in number of emails sent in one step, 50 by defaut in most cases. If you have more than 50 recipients, you can submit the emailing from screen a second time and the application will automatically send emails to the 50 next recipients. Repeat until all recipients are addressed.
- or from the command line with script Script mailing-send.php.
Only an emailing with the status Validated can be sent by the script. See page Script mailing-send.php for more information on how to launch it from command line.
