Module EMailing
| Mailing | |
| Numero/ID of module | 22 |
| Developer doc. of module | Module EMailing (developer) |
Check also that Dolibarr setup to send mails is ok: Setup EMails
Note: If a constant MAILING_NO_USING_PHPMAIL is set to 1 in Home - Setup - Other, it is only possible to send emailing when setup is not on "PHP Mail" but on another option (like "SMTPs").
Mass E-Mailing features are available from menus (if Module EMailing has been activated). Menu link can be found in menu "Tools" with default menu manager "Eldy".
Life cycle / Business rules
The full process is this one:
- Then you choose the targets, among predefined dynamic lists from your Dolibarr data or from external files (For this, go on tab "Recipients" and click on button "Add" for predefined lists you want).
- You can modify this list, by removing targets for example.
- the web application screen. In such a case, there is a limit in number of emails sent in one step, 50 by defaut in most cases. If you have more than 50 recipients, you can submit the emailing from screen a second time and the application will automatically send emails to the 50 next recipients. Repeat until all recipients are addressed.
- or from the command line with script Script mailing-send.php.
Only an emailing with the status Validated can be sent by the script.
See page Script mailing-send.php for more information on how to launch it from command line.
