Module OAuth
| OAuth | |
| Numero/ID of module | 66000 |
| Developer doc. of module | |
- for SMTP email sending
- for the IMAP EMail collector
- for some external modules
Creation of the OAuth entry
For SMTP access
For Google
For Microsoft Office365
For IMAP access
For Google
For SSO Login
For Google
You must also modify you Dolibarr conf file to use SSO Login with Google OAuth. See page Authentication,_SSO_and_SSL.
Not yet available ! Will probably be ...
Other services
For Mastodon read/write
URL for endpoint termination: Should be the root url of the Mastodon server; For example: https://mastodon.social
Client ID / Secret ID: You can get them from your Mastodon profile account.
Scope: Type read,write
Generation of the token
Note about token duration of validity
- For Google, when your oauth entry is published is Testing, Google unverified, the refresh_token expires is 7 days and is limited to 100 access_token refreshes.
- For Google, when your oauth entry is published in Production, Google verified, refresh_token expire is 180 days and has unlimited access_token refreshes.
For Microsoft 365
The following steps are:
- Go on https://portal.azure.com - Manage application to create an Application. You can get the value for Client ID in field "ID application (client)" and Tenant ID in field "ID annuary (tenant)"
- Then set property "Assignation required to No (not sure this is necessary)
- Then set Authentification chapter to add the allowed callback URL suggested by Dolibarr.
- Then set Authorized API, for example Microsoft Graph email, IMAP.ACcessAsUser.ALL, Mail.Read, Mail.Send, offline_access, openid, profile, SMTP.Send
- Then set Certificate & Secret (The Secret ID is column "Value", the column "ID of secret" can be ignored)
You can get a summary of all of this in the menu "Overview"
The is some documentation here:
- See https://afterlogic.com/mailbee-net/docs/OAuth2Office365NonInteractive.html and https://learn.microsoft.com/fr-fr/exchange/client-developer/legacy-protocols/how-to-authenticate-an-imap-pop-smtp-application-by-using-oauth
- Tutorial to register an application and create a secret ID: https://learn.microsoft.com/fr-fr/azure/active-directory/develop/quickstart-register-app#register-an-application
- A thread in forum is also available related to use of OAuth2 for SMTP and IMAP: https://www.dolibarr.org/forum/t/oauth-office-365-and-email-collector/23437
For Google
