Module OAuth
Revision as of 19:33, 1 October 2024 by Eldy (talk | contribs) (→‎For Google)
OAuth
Numero/ID of module 66000
Developer doc. of module
Creation of the OAuth entry
For SMTP access
For Google
For Microsoft Office365
For IMAP access
For Google
For SSO Login
For Google
Not yet available ! Will probably be ...
Generation of the token
Note about token duration of validity
  • For Google, when your oauth entry is published is Testing, Google unverified, the refresh_token expires is 7 days and is limited to 100 access_token refreshes.
  • For Google, when your oauth entry is published in Production, Google verified, refresh_token expire is 180 days and has unlimited access_token refreshes.
For Microsoft 365
The following steps are:
  • Go on https://portal.azure.com - Manage application to create an Application. You can get the value for Client ID in field "ID application (client)" and Tenant ID in field "ID annuary (tenant)"
  • Then set property "Assignation required to No (not sure this is necessary)
  • Then set Authentification chapter to add the allowed callback URL suggested by Dolibarr.
  • Then set Authorized API, for example Microsoft Graph email, IMAP.ACcessAsUser.ALL, Mail.Read, Mail.Send, offline_access, openid, profile, SMTP.Send
  • Then set Certificate & Secret (The Secret ID is column "Value", the column "ID of secret" can be ignored)
You can get a summary of all of this in the menu "Overview"
The is some documentation here:
For Google
