Module OAuth
| OAuth | |
| Numero/ID of module | 66000 |
| Developer doc. of module | |
- for SMTP email sending
- for the IMAP EMail collector
- for some external modules
Creation of the OAuth entry
For SMTP access
For Google
For Microsoft Office365
For IMAP access
For Google
For SSO Login
For Google
Not yet available ! Will probably be ...
Generation of the token
Note about token duration of validity
- For Google, when your oauth entry is published is Testing, Google unverified, the refresh_token expires is 7 days and is limited to 100 access_token refreshes.
- For Google, when your oauth entry is published in Production, Google verified, refresh_token expire is 180 days and has unlimited access_token refreshes.
For Microsoft 365
The following steps are:
- Go on https://portal.azure.com - Manage application to create an Application. You can get the value for Client ID in field "ID application (client)" and Tenant ID in field "ID annuary (tenant)"
- Then set property "Assignation required to No (not sure this is necessary)
- Then set Authorized API
- Then set Authentification chapter
- Then set Certificate & Secret (The Secret ID is column "Value", the column "ID of secret" can be ignored)
The is some documentation here:
- See https://afterlogic.com/mailbee-net/docs/OAuth2Office365NonInteractive.html and https://learn.microsoft.com/fr-fr/exchange/client-developer/legacy-protocols/how-to-authenticate-an-imap-pop-smtp-application-by-using-oauth
- Tutorial to register an application and create a secret ID: https://learn.microsoft.com/fr-fr/azure/active-directory/develop/quickstart-register-app#register-an-application
- A thread in forum is also available related to use of OAuth2 for SMTP and IMAP: https://www.dolibarr.org/forum/t/oauth-office-365-and-email-collector/23437
For Google
TODO
