Module OAuth
OAuth | |
Numero/ID of module | 66000 |
Developer doc. of module |
- for SMTP email sending
- for the IMAP EMail collector
- for some external modules
Creation of the OAuth entry
For SMTP access
For Google
For Microsoft Office365
Client ID / Secret ID: See chapter [How to get my Client / Secret ID].
For IMAP access
For Google
For SSO Login
For Google
Not yet available ! Will probably be ...
Generation of the token
Note about token duration of validity
- For Google, when your oauth entry is published is Testing, Google unverified, the refresh_token expires is 7 days and is limited to 100 access_token refreshes.
- For Google, when your oauth entry is published in Production, Google verified, refresh_token expire is 180 days and has unlimited access_token refreshes.
To create an OAuth entry, you need a Client and Secret ID (an sometimes a Tenant ID). Getting them depends on your OAUTH provider.
For Microsoft 365
The following steps are:
- Go on https://portal.azure.com - Manage application to create an Application
- Then set property "Assignation required to No (not sure this is necessary)
- Then set Authorized API
- Then set Authentification chapter
- Then set Certificate & Secret
The is some documentation here:
- See https://afterlogic.com/mailbee-net/docs/OAuth2Office365NonInteractive.html and https://learn.microsoft.com/fr-fr/exchange/client-developer/legacy-protocols/how-to-authenticate-an-imap-pop-smtp-application-by-using-oauth
- Tutorial to register an application and create a secret ID: https://learn.microsoft.com/fr-fr/azure/active-directory/develop/quickstart-register-app#register-an-application
- A thread in forum is also available related to use of OAuth2 for SMTP and IMAP: https://www.dolibarr.org/forum/t/oauth-office-365-and-email-collector/23437
For Google
TODO
The is some official documentation here:
