Module OAuth
Revision as of 17:47, 1 October 2024 by Eldy (talk | contribs) (→‎Setup)
OAuth
Numero/ID of module 66000
Developer doc. of module
Creation of the OAuth entry
For SMTP access
For Google
For Microsoft Office365
Client ID / Secret ID: See chapter [How to get my Client / Secret ID].
For IMAP access
For Google
For SSO Login
For Google
Not yet available ! Will probably be ...
Generation of the token
Note about token duration of validity
  • For Google, when your oauth entry is published is Testing, Google unverified, the refresh_token expires is 7 days and is limited to 100 access_token refreshes.
  • For Google, when your oauth entry is published in Production, Google verified, refresh_token expire is 180 days and has unlimited access_token refreshes.
To create an OAuth entry, you need a Client and Secret ID (an sometimes a Tenant ID). Getting them depends on your OAUTH provider.
For Microsoft 365
The following steps are:
  • Go on https://portal.azure.com - Manage application to create an Application
  • Then set property "Assignation required to No (not sure this is necessary)
  • Then set Authorized API
  • Then set Authentification chapter
  • Then set Certificate & Secret
The is some documentation here:
For Google
TODO
The is some official documentation here:
