Module EMail Collector
| EMailCollector | |
| Numero/ID of module | 50320 |
| Developer doc. of module | Module EMail Collector (developer) |
This module permits to collect emails from a mailbox using the IMAP protocol and record event or data in your Dolbarr using information found into email.
If available, it is recommended to enable the option "Use the PHP-IMAP library for IMAP instead of native PHP IMAP. This also allows the use of an OAuth2 connection for IMAP (module OAuth must also be activated)." so when creating an email collector, you will be able to choose between IMAP login with user/pass or with an OAuth2 token.
Create an email collector
Create as many email collectors you need.
Host of email IMAP server: Enter the full name of the IMAP server. Exemple: imap.gmail.com
Port of email IMAP server / Imap encryption: Choose 993 / SSL
Host charset: Choose UTF-8 (works 95% of time). May be US-ASCII with some version/setup of Office365.
Authentication mode
- If you choose "Password", you must set an IMAP login and password.
- If you choose "OAuth2", you must set the IMAP login and set the OAuth2 entry to use into the field Oauth service. To create your OAuth2 entry and choose the correct permission for this entry see documentation of Module OAuth
Source directory
- To collect received email, enter here "INBOX"
- To collect email sent, enter here "Sent"
Target directory A good practice is to move the collected email into another folder to avoid to have them collected twice. You must create the output target IMAP directory manually before running your email collector.
For example, with Gmail, to create a new IMAP directory:
- Sign in to your Gmail account.
- At the top right of the Gmail window, click Settings See all settings.
- Click Labels.
- Create Label and check the box "Show in IMAP"
Filters
Choose criteria to define which email is qualified for the collect.
Operations to do
Choose the action to do on collected emails.
Let the job scheduler (Module Scheduled jobs) being executed automatically to run the Email collectore and see your data being recorded into Dolibarr.
To avoid to wait the batch, you can force to execute the email collector manually from the Email collector record with the button "Run now". When making test, a good practice is to set the maximum number of email collected to a low value.
A test mode is available (button Test). This mode does not cause any modification of your mailbox (just reading) nor modification in Dolibarr. On the other hand, it allows you to see the different stages of the selection of qualified email, the filter and the processing of the actions that would be applied if we were not in test mode. This is an important feature to fine-tune the configuration of the collector.
Boundary Value Analysis
Use Cases
The following use cases were tested for some version of Dolibarr and mail providers:
| Use Case | GMail + Dolibarr 20 | Errors / Problems |
| Collect received mails to create a ticket (created from scratch by someone) | OK | |
| Answer the ticket email received by email, this answer appears into the "Email sent", the collector collect the email sent and link it to the ticket. | OK | |
| Send email from a Dolibarr ticket. The email must appears into "Email Sent" of the mailer, but the email collector must not collect it from the "Email sent" because it will be a double: When the email is generated and sent from Dolibarr (so saved into Dolibarr), and the SMTP platform also save the email into the "Emails sent", the collector we must not re-import it. | ??? | |
| Collect and link email to the ticket for email received from the customer answer of our answer (sent from ticket interface). | OK | |
| Collect and link email to the ticket for email received from the customer answer of our answer (sent from the emailer) | OK | |
| Collect and link email to the ticket for email sent from the emailer on a mail that was an answer of a ticket. | OK |
Filters
Depending on your mailbox service, some filters may works or not. This is a summary of tests done with different email services. When your mail hoster does not support the filter, Dolibarr may use the PHP to have filter working despite of this. But this is not always implemented.
| Filters/Technology used to filter | Office365 | GMail | Dolibarr+PHP | Errors / Problems |
| From | OK | NA | ||
| To | OK | NA | ||
| Cc | KO | ? | Search string not understood - Unknown search criterion: CC | |
| Bcc | KO | ? | Search string not understood - Unknown search criterion: BCC | |
| ReplyTo | NA | Filter support with Dolibarr 20+ | ||
| Subject | OK | NA | ||
| Body | OK | NA | ||
| Already read | OK | NA | ||
| Unread | OK | NA | ||
| Unanswered | OK | NA | ||
| Answered | OK | NA | ||
| Size (Smaller than) | KO | NA | Search string not understood - Unknown search criterion: SMALLER | |
| Size (Larger than) | KO | NA | Search string not understood - Unknown search criterion: LARGER | |
| Message from a conversation initiated by a first email sent from Dolibarr | NA | OK | ||
| Message from a conversation initiated by a first email NOT sent from Dolibarr | NA | OK | ||
| Message sent from Dolibarr | NA | OK | ||
| Message NOT sent from Dolibarr | NA | OK | Message not processed but not an error | |
| Is not answer (initial email) | NA | OK | ||
| Is an answer of an initial email | NA | OK |
