Module OAuth
OAuth
Numero/ID of module 66000
Developer doc. of module
Creation of the OAuth entry
For SMTP access
For Google
For Microsoft Office365
For IMAP access
For Google
For SSO Login
For Google
Not yet available ! Will probably be ...
Generation of the token
Note about Google OAuth token duration - When your oauth entry is published is Testing, Google unverified, the refresh_token expires is 7 days and is limited to 100 access_token refreshes. - When your oauth entry is published in Production, Google verified, refresh_token expire is 180 days and has unlimited access_token refreshes.
For Microsoft
https://learn.microsoft.com/fr-fr/azure/active-directory/develop/quickstart-register-app#register-an-application
For Google
See https://support.google.com/cloud/answer/6158849
