Module OAuth
OAuth
Numero/ID of module
Developer doc. of module
Creation of the OAuth entry
For SMTP access
For Google
For Microsoft Office365
For IMAP access
For Google
For SSO Login
For Google
Not yet available ! Will probably be ...
Generation of the token
Once your OAuth entry has been created, you can switch on the second tab to generate and get your OAuth token. This token will then be used by the other modules or features (for example, to send email using SMTP or to read emails using IMAP).
For Microsoft
https://learn.microsoft.com/fr-fr/azure/active-directory/develop/quickstart-register-app#register-an-application
For Google
See https://support.google.com/cloud/answer/6158849
