Module HelloAsso
Module name HelloAsso
Dolibarr min version: 20    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2024-03-20
Add into Dolibarr, a HelloAsso online payment page (credit/debit cards). This can be used to allow your customers to make ad-hoc payments or payments related to a specific Dolibarr object (invoice, order etc...)
Prerequisites
This module requires an instance of Dolibarr version 20 or +.
From the application
Manually
unzip modulefile.zip
1) First go on the setup page of HelloAsso module in Dolibarr
Setup for sandbox mode
2) Next you need to connect to your HelloAsso-sandbox account to get and fill 3 fields in Dolibarr:
  • Client organization test with the organization you want the checkout to be done
  • Client id test key (Blue square on the image)
  • Client secret test key (Red square on the image)
The two keys can be found on your HelloAsso-sandbox account in the menu My Account > Integrations and APIs
Setup for live mode
2) The next thing you need to do is enable the Live mode by setting On Helloasso live enabled button.
3) Next you need to connect to your HelloAsso account to get and fill 3 fields in Dolibarr:
  • Client organization live with the organization you want the checkout to be done
  • Client id live key (Blue square on the image)
  • Client secret live key (Red square on the image)
The two keys can be found on your HelloAsso account in the menu My Account > Integrations and APIs
Development and contributions
Troubleshooting
