Module HelloAsso
Module name | HelloAsso |
Editor / Editeur | DoliCloud - www.dolicloud.com |
Prerequisites / Prérequis |
Dolibarr min version: 20 Dolibarr max version: {{{maxversion}}} |
Last update date / Date mise à jour fiche / Fecha última actualización | 2024-03-19 |
Note / Nota |
Add into Dolibarr, a HelloAsso online payment page (credit/debit cards). This can be used to allow your customers to make ad-hoc payments or payments related to a specific Dolibarr object (invoice, order etc...)
Prerequisites
This module requires an instance of Dolibarr version 20 or +.
From the application
Manually
unzip modulefile.zip
1) First go on the setup page of HelloAsso module in Dolibarr
Setup for sandbox mode
2) Next you need to fill 3 fields:
- Client organization test with the organization defined in your HelloAsso sandbox profile
- Client id test key (Blue square on the image)
- Client secret test key (Red square on the image)
The two keys can be found on your HelloAsso-sandbox account in the menu My Account > Integrations and APIs
Setup for live mode
Development and contributions
- Repository: https://github.com/DoliCloud/DoliMods.git
