Module OAuth
OAuth | |
Numero/ID of module | |
Developer doc. of module |
The OAUth module is a technical module that allow you to create and manage OAuth2 connections with an external system. Alone this module is useless. But once you have created OAuth2 connections, you can reuse them in some other modules, for example:
- for SMTP email sending
- for the EMail collector
- for some external modules
Creation of the OAuth entry
For IMAP access
For Google
For Microsoft Office365
Scope: Choose the scope: https://outlook.office365.com/IMAP.AccessAsUser.All. It if fails, choose: https://outlook.office.com/.default
For SMTP access
For Google
Scope: Choose the scope: https://outlook.office365.com/SMTP.Send. It if fails, choose: https://outlook.office.com/.default
For SSO Login
This is example of setup if you plan to use the OAuth provider to login. Note that for this purpose, creating the entry is enough, no need to generate the token.
For Google
Not yet available.
Generate the token
Once your OAuth entry has been created, you can switch on the second tab to generate and get your OAuth token. Note: If the goal if the OAuth entry is to be used for SSO Login, you don't need to generate the token.
For Microsoft
