Module OAuth
OAuth
Numero/ID of module
Developer doc. of module
The OAUth module is a technical module that allow you to create and manage OAuth2 connections with an external system. Alone this module is useless. But once you have created OAuth2 connections, you can reuse them in some other modules, for example:
Creation of the OAuth entry
For IMAP access
  • For Google*
Client ID / Secret ID: See chapter External documentation. Scope: Choose the scope *gmail_full*
  • For Microsoft Office365*
Client ID / Secret ID: See chapter External documentation. Scope: Choose the scope: *https://outlook.office365.com/IMAP.AccessAsUser.All*. It if fails, choose: *https://outlook.office.com/.default*
For SMTP access
  • For Google*
Client ID / Secret ID: See chapter External documentation. Scope: Choose the scope: *https://outlook.office365.com/SMTP.Send*. It if fails, choose: *https://outlook.office.com/.default*
For SSO Login
This is example of setup if you plan to use the OAuth provider to login. Note that for this purpose, creating the entry is enough, no need to generate the token.
  • For Google*
Client ID / Secret ID: See chapter External documentation. Scope: Choose the scope *openid* and *email*
Client ID / Secret ID: See chapter External documentation. Scope: Choose the scope *https://outlook.office.com/.default*
Generate the token
Once your OAuth entry has been created, you can switch on the second tab to generate and get your OAuth token. Note: If the goal if the OAuth entry is to be used for SSO Login, you don't need to generate the token.
For Microsoft
https://learn.microsoft.com/fr-fr/azure/active-directory/develop/quickstart-register-app#register-an-application
For Google
For GitHub
For a Generic OAuth2 system
