Module Ticket
Ticket
Numéro/ID du module 56000
Doc développeur du module Module Ticket (developper)
This module allow you to manage a Help Desk service. You can create and follow tickets from the backoffice but also from a light public portal.
Public interface
There is a public interface available to create an view tickets: <your dolibarr URL>/public/ticket/
You can protect the public page with a Captcha. This can be enabled under Home -> Settings -> Security where you can set a switch regarding Captchas on public pages.
Workflow
The default workflow of a ticket is (number in parenthesis is the numero of status):
                                             --> on Hold (7) --->
Not read (0) ---> Read (1) --> Assigned (2) --> In progress (3) ------------>  Closed/Solved (8)
                                       Waiting feedback requester (5)
                      Canceled (9)
Create a ticket from backoffice
Create a ticket from the public interface
