Module Ticket
| Ticket | |
| Numéro/ID du module | 56000 |
| Doc développeur du module | Module Ticket (developper) |
This module allow you to manage a Help Desk service. You can create and follow tickets from the backoffice but also from a light public portal.
Workflow
The default workflow of a ticket is (number in parenthesis is the numero of status):
<- on Hold (7) ->
Not read (0) ---> Read (1) --> Assigned (2) --> In progress (3) ------------> Closed/Solved (8)
Waiting feedback requester (5)
Canceled (9)
Create a ticket from backoffice
Create a ticket from the public interface
There is a public interface available to create an view tickets: <your dolibarr URL>/public/ticket/
You can protect the public page with a Captcha. This can be enabled under Home -> Settings -> Security where you can set a switch regaring Captchas on public pages.
