Module Agenda
Revision as of 10:11, 4 August 2023 by ShengGang (talk | contribs) (Add Chinese)
Agenda
Numero/ID of module 2400
Developer doc. of module Module Agenda (developer)
The Agenda Module is a core Dolibarr module. It is optional and part of the Projects/Collaborative work group in module list.
The main purpose of the module is to add a calendar into Dolibarr and manage events.
The term Events is often confused with terms like "Tasks", "Action", "list of Tasks", "Journal".
If you are not familiar with these, read this summary page : Events-Todo-Journal.
What this module does
  • Manage a calendar of events (also called Agenda).
  • Support day, week, month view for calendar.
  • Support displaying other external calendars in agenda using ical URL.
  • Support also user and list view of events.
  • Allow to define and use types for event categorization.
  • Allow to link a project, a third party and a contact to an event.
  • Allow to link documents and/or URL to an events.
  • If the Resources module is activated, you could link resources to an event.
  • Support extra fields for event.
  • Support the automatic agenda filling by Dolibarr workflow events.
  • Support calendar events export using vcal, ical or rss.
What this module does not
  • Does not support updating external calendar. (see commercial modules for this).
  • Does not support recurring events.
To know how to setup the module to export Dolibarr agenda events it into the Google agenda, see FAQ Agenda EN.
The events (event)
In Dolibarr, we also call this events the actions. There is some automatic actions (created automatically by Dolibarr) and manual actions (created explicitly by users). This is the role of Agenda module to manage this kind of events.
Automatic events
We can setup in the Agenda module, which event we want to create automatically into the calendar. Events chosen (invoice creation, order validation...) are then created automatically into the calendar. So such events are business actions that has just been done. They are created with status realized (percentage of accomplishment = 100%). Duration of such events are in general 0 seconds (end date = start date)
Manual events and rendez-vous
You can also create yourself events from Agenda menus. So you create, modify, delete an event (named action into Dolibarr). Such events will have a start date, an end date, an accomplishment percentage, all chosen by user. This properties can also be modified later.
Related videos
