These are some rules on language, syntax and norm we use in the Dolibarr project:
Versions
  • Dolibarr must work on:
  3. MySQL 5.1+
Copyright Norms
<?php
 * Licence information
PHP Norms
PHP
  • Dolibarr is written with PHP and supports all versions of PHP higher than 7.1.0+. All files must end with extension .php
  • Usage of PHP superglobals variables must use the dedicated operators $_COOKIES, $_SERVER, $_ENV but use the Dolibarr function GETPOST() to get the contents of $_GET or $_POST..
  • Other operators ($HTTP_SERVER_GET, ...) are now deprecated in PHP, so they must not be used. Code must work if option register_long_arrays is set to off. Moreover, the code must work when PHP option register_globals is off (recommended by PHP). It must also work if the option register_globals is on (by default on a lot of installations).
  • Do not use PHP_SELF. Use instead $_SERVER["PHP_SELF"]. Also, Dolibarr framework sanitizes content of $_SERVER["PHP_SELF"] variable (into main.inc.php file, before any business code).
  • When several variables must be initialized with the same value, you must use individual declarations (separated by ;)
$var1 = 1;
$var2 = 1;
$var3 = 1;
instead of
$var1 = $var2 = $var3 = 1;
which is slower.
Strings
  • Strings must be have variables outside of the quote.
print "My text show my ".$variable." !\n";
Comments
/* Bloc of comment
 * End of bloc
    // comment on one line
    print $i;
    // code
  • Coding style to use is the PSR-12 (https://www.php-fig.org/psr/psr-12/). Only rules tagged "MUST" are currently required. So note however the exceptions:
    • We allow elements of an array on same line and we do not always add a new line at end of each element.
    • Note 2: You can use the file dev/setup/codesniffer/ruleset.xml as rule file to control coding style with PHPCodeSniffer.
    • Note 3: You can use the file dev/setup/eclipse/PSR-12 [built-in].xml as rule file to setup Eclipse syntax formater.
    • Note 4: You may note that current code is not yet compliant with the PSR-12. The reason is that we must "now" follow the "MUST" rules of PSR-12, but it wasn't in the past. So feel free to change coding style to match new rules (keep in mind the 2 exceptions) if you find such cases.
SQL and Database rules
DDL file format
create table llx_mytable
  field_one   integer,
  field_two   integer NOT NULL,
  fk_field    integer,
  field_date  datetime,
)type=innodb;
Table and fields structures
  • Structure of tables.
- import_key      varchar(32)                 that will contain the import code YYYYMMDDHHMMSS if you make mass import
Optional
- fk_user_creat or fk_user_author integer that is the id of user making creation
Note field:
- note_public text for public comment of the object
or
  • Type of fields:
To be compatible with any accuracy required by any country on amounts, to be compatible with any database syntax and with the Dolibarr upgrade framework, we will use the following types for database fields:
- double(24,8) for any amount
- real for a quantity
- date for a field date
All business rules must be in the same place, in PHP code, not in the client or the database, that's why type enum is also not allowed. Other types are not allowed for compatibility reasons.
  • All tables have a prefix to avoid name conflicts with other projects. In the current version this prefix is fixed and can't be modified. Its value is llx_. In a future version this value should be modified during installation process.
Primary keys
Some old tables do not use this rule and use a primary key called id (e.g. Table llx_c_actioncomm). The reason is historical and this should not happen anymore.
Foreign keys
Alternative keys
Sometimes, we need other unique keys than primary key. When we need this, we can create an alternate unique key. Such a key should have a name that starts with uk_, then the table name (this is required to avoid duplicate names of unique keys that may create problems for some DBMS like Postgresql) and then another string to define the key (this is to allow having several unique keys on the same table).
Index performance
SQL Coding rules
  • Alias usage/Fields naming
Example:
  • SQL Date functions NOW, SYSDATE or DATEDIFF are forbidden inside SQL requests. Other functions like (MONTH, YEAR) must also be avoided if possible. If you must use the current date into a field, value must come from the PHP and not from the database engine. This is for 3 reasons:
    • better portability of code
    • better management of TimeZone (reference timezone is the PHP timezone and timezone of database may differs so all dates functons must be on PHP side).
    • better performance (see example and final comment)
For example, don't do:
but do:
but do:
  • The statement WITH ROLLUP is prohibited:
This statement should not be used: it is not handled the same way by different databases. Also, using WITH ROLLUP breaks the purity of the returned data. The intermediate subtotal generation aggregation performed by this statement can easily be done using PHP and helps keep the returned data array clean (not corrupted by artificially inserted data).
  • Use $db->ifsql for SQL IF
  • No DELETE CASCADE and ON UPDATE CASCADE
Such SQL instructions are forbidden because they bypass the business rules of the application bringing a lot of troubles out of control of the developers. For example, if there is a delete cascade between table A and B, when the application will execute the code to remove a record in A, the children into table B will also be removed. If there was a Dolibarr PHP trigger (for example bring by an external module) on the deletion of record of B (for example to validate the deletion or to execute a complementary action), the DELETE CASCADE will be executed without having the Dolibarr PHP trigger executed, missing the validation or actions of the PHP trigger of the module. All business rules must be implemented on the same side (so the server PHP side), this is the reason why business rules implemented on Database side are not allowed (same conclusion than the next point about Database triggers). Note that external modules can use them for links between Dolibarr tables and its module tables but a better recommanded solution is to use the trigger to implement the deletion of its table when a record of a parent official table is deleted.
Using Database triggers
Using Database triggers is not allowed into the code of Dolibarr, so you should have no troubles with Database triggers. Database triggers are not portable. Compatibility may be broken when upgrading your version of your database, database triggers are often not included into backup tools, database triggers need permissions that you may not have (and should not have) on a common secured database, database triggers means also that you include some "business rules" of your application into the database where most other rules are managed by the code itself (this can create conflict or code that can't be debugged with a step by step debugger), database triggers execute code using the timezone of the database instead of the reference timezone of application that may be different (generating offset into database) ... There is tons of reason why we do not recommend to use database triggers in your own development. Using Database triggers can save you time when you make development but is a very bad practice, so is forbidden as it is not compatible with the high level of quality of code expected by Dolibarr team. External modules that uses Database triggers may also be refused on the market place since it won't work for more than 50% of users.
MySQL-MariaDB specificity
  • Dolibarr MUST work even if MySQL option strict is active.
To activate it (required when developing on Dolibarr), add the following line into the config file of your MySQL server (my.cnf or my.ini)
sql-mode="STRICT_ALL_TABLES,ONLY_FULL_GROUP_BY,NO_ZERO_DATE,NO_AUTO_CREATE_USER,NO_ENGINE_SUBSTITUTION"
PostgreSQL specificities
Only MySQL files must be maintained. Those files are converted "on the fly" by the database Dolibarr driver.
MySQL Syntax:
UPDATE table_target as target, table_source as source SET fieldtarget=source.fieldsource
PgSQL Syntax:
UPDATE table_target as target SET fieldtarget=source.fieldsource
There is no native SQL requests "UPDATE FROM" in all Dolibarr core. But if you use one in your own code of your module, you should do :
$sql="UPDATE table_target as target SET fieldtarget=source.fieldsource
} else {
$sql= "UPDATE table_target as target, table_source as source SET fieldtarget=source.fieldsource
HTML norms
Syntax rules
For example:
External template framework ?
There is ton of frameworks to provide a template language of an HTML page (smarty, twig, ...). The best and faster on we know is just called "PHP", and because Dolibarr already depends on PHP, there is no need to introduce a dependency on a third language to make templates.
All template frameworks are just pre-processor, BEFORE PHP. It can't be faster than PHP alone. When we say "speed is increased because template framework use a cache", you must read in fact "the overtime spent by the framework is reduced by cache, not the speed of processing PHP file". We should say "any template framework has an overload over PHP, the cache of the template framework just reduces the slowing effect of using this framework", but not "the speed is increased, it is always decreased compared to pure PHP".
Above all, having a template system is completely possible by doing a ".tpl.php" file that dos not contains any logic code, but only HTML and print of variables. We get same result (but faster and easier to develop because it does not need to do all the setXXX before calling each template). All variables (known by code that include the template) are automatically known into a PHP template page. No risk to forget a set, and a lot of line of codes reduced, a lot of time and development errors are also saved.
Also, keeping a guarantee of 100% of isolation between code and HTML output is interesting in only 1 situation: When teams building design is completely different than team building logic code, AND if you build not too sophisticated pages, AND with no need of too many Ajax features (this need to know how code works). And this situation is surely not the Dolibarr future (team will often be same, Ajax will be more and more present, event if I hope not too much, and screens are more and more dependent of dynamic or contextual events, difficult to have this with one simple template without transforming the template into a page with high level of code). Also design if more an more managed now in CSS side instead of PHP side.
In the past, Dolibarr has experimented a template system like smarty. If on the paper the idea was good, we quickly realized that finding a bug become a headache, coding become a treasure hunt, maintenance and development were done so slower (compared to previous situation where output templates are into the "View" section of each PHP file) that we forgot this idea. Pragmatism has made the rule.
There is a ton of other reasons to not use an external template system and all arguments to use them are also the best argument to use HTML/PHP as our template system. We just ask to keep separation between Controllers (the first section of PHP pages juste after the /* Action */ line), and the Views, the second section after the /* View */ comment).
Skeleton code
For example:
Dates and Timezones
UTF8/ISO encoding
  • Web pages are returned and rendered into UTF8
print 239.2 - 229.3 - 9.9;
Creation of tables
Comparing version
Logs
Working directory
dol_mkdir($mymoduledir);
Patterns of code organization
  • The Domain Model
  • The Table Module
  • The Active Record
  • The Data Mapper
Design pattern for Graphic interfaces (MVC)
There are several design patterns for user interfaces (MVC, MVP, MVVM). Many confuse this design pattern with that of using a template framework. It's unrelated. A template framework (see previous point) is only linked to the "V" part of these models.
-> Dolibarr uses the MVC Design Pattern. Part M is materialized by a DAO class containing the CRUD (Create-Read-Update-Delete) methods for accessing the table. Many frameworks have chosen to put the C code part (Controller) and the V code part (View) in different files, or even separate directories. The maintenance seems easier on paper, in practice, you have to juggle constantly between a ton of files when your project become larger. In Dolibarr, the separation is made by a simple comment section. The part of code C (Controller) is therefore the code that follow the tag
 * Actions
It is followed by the part of code V (Vue), well separated from the C by the tag
 * View
This mode of separation has had a neutral effect on new developments but has made it possible to reduce the time required for maintenance and fixing bugs so significantly that it is not envisaged to switch to another type of separation (yes the findings made in real life are not always those expected by school theory). The important thing remains that there is always a separation between C and V, no matter how this separation is materialized, as long as it is (Reminder: Do not confuse the notion of separation of C and V with the notion of separation of the code to feed the data of a View and of the code to format the View, this a principle of separation relating to the Design Pattern of Vue, see next point).
Design pattern for Views - Presentation
There are frameworks that specialize in Vue Design Pattern, the part of formatting the screen seen by the user. Old versions of Dolibarr used Smarty. This framework is an overlay to an already very powerful screen formatting framework called ... PHP. The benefits being much lower than the disadvantages, it has been abandoned in favor of PHP templates (.tpl.php file) which remain the simplest, the most universal, the most scalable and the most efficient, of the presentation frameworks.
Its only flaw is that it cannot guarantee 100% the deviations of a developer who would integrate into the View, a logic unrelated to the presentation (therefore other than code intended for generation, formatting, HTML output , test or loop logic). This point is however controlled by the validation mechanism of the project managers' code.
Here again, it is the experience and the observation of a better productivity performance that has motivated the abandonment of the external Presentation frameworks in favor of the PHP framework.
