Table llx facturedet
Revision as of 14:34, 18 April 2023 by Elsp1991 (talk | contribs) (fill in the description of fk_code_ventilation)
Content/Contenu/Contenido
Contains the lines of customer invoices, this table is linked with Table llx_facture.
Contient les lignes des factures clients, cette table est liée avec la Table llx_facture.
Contiene las líneas de las facturas a clientes, esta tabla está vinculada con Table llx_facture.
Structure
Table
rowid integer NO PRI auto_increment technical index
fk_facture integer NO MUL 0 ID of invoice (Table llx_facture->rowid)
fk_product integer YES NULL ID of product (Table llx_product->rowid)
description text YES NULL description of customer invoice line
tva_tx double(24,8) YES NULL line VAT taxes
localtax1_tx double(24,8) YES NULL localtax1_tx
localtax1_type integer YES NULL localtax_type
localtax2_tx double(24,8) YES NULL localtax2_tx
localtax2_type integer YES NULL localtax2_type
qty real YES NULL quantity of the product or service
remise_percent double(24,8) YES 0 discount percentage
remise double(24,8) YES 0 discount amount
fk_remise_except integer YES UNI NULL ID of discount (llx_societe_remise_except->rowid)
subprice double(24,8) YES NULL price before discount
price double(24,8) YES NULL deprecated
total_ht double(24,8) YES NULL total excluding taxes
total_tva double(24,8) YES NULL total tax
total_localtax1 double(24,8) YES NULL total local tax 1
total_localtax2 double(24,8) YES NULL total local tax 2
total_ttc double(24,8) YES NULL Total including discount and taxes (vat + localtax1 + localtax2)
product_type integer YES 0 Type of product
date_start datetime YES NULL start date if service
date_end datetime YES NULL end date if service
info_bits integer YES 0 TVA NPR or not
buy_price_ht double(24,8) YES 0 TVA NPR or not
fk_code_ventilation integer NO 0 ID of accounting code (llx_accounting_account->rowid)
fk_export_compta integer NO 0 ID of acountacy export (llx_export_compta->rowid)
special_code integer YES 0 0=default, 1=seems no more used (or may be used to set line as transport/shipping fee), 2=used by WEEE module to define line as a WEEE line, 3=option line (price must not included in total), 4=Sent for cooking (POS modules for restaurant), Module ID (>= 5)=value for a custom need. Value is an additional information and has no effect, except value 3 that means "do not take into account amount, it is an option" (so price must not be included in total, qty in this case should be also 0).
rang integer YES 0 Position of line. Lower value are line top, higher value are bottom.
import_key varchar(14) YES NULL Code used to save the import id. See page Field Import key.
Keys
Key Type Fields
PRIMARY PRIMARY rowid
uk_fk_remise_except UNIQUE fk_remise_except
idx_facturedet_fk_facture MULTIPLE fk_facture
