Module Reception
Revision as of 11:08, 10 April 2023 by Eldy (talk | contribs) (→‎Configuration)
Receiption
Numero/ID of module
Developer doc. of module Module Reception (developer)
With this module you can manage accurate reception of products.
Note: For shipments, see Module Shipments.
When the module is activated, it becomes possible to create a reception from a purchase order. The workflow for a reception is as follows:
Draft (0) ---X---> Validated = Prepared / To receive or received (1) ---X---> Processed (Closed / Received) '' (2)
Note:
  • For status other than "Draft", the quantity can no longer be modified.
  • Number in parenthesis: Numeric value of the status in the database
  • X means that the stock can be automatically decremented during this step (depending on the stock decrement configuration of Stock Module).
