Module Ticket
Revision as of 13:07, 22 December 2022 by Eldy (talk | contribs) (→‎Configuration)
Ticket
Numéro/ID du module 56000
Doc développeur du module Module Ticket (developper)
This module allow you to manage a Help Desk service. You can create and follow tickets from the backoffice but also from a light public portal.
Workflow
The default workflow of a ticket is:
                                            <- Pending (7) ->
Draft (0) ---> Read (1) --> Assigned (2) --> In progress (3) ----------------------------------->  Closed (8)
                                     \               |                                      \--->  Abandoned (9)
                                      \--<-- Waiting feedback requester (5)
Create a ticket from backoffice
Create a ticket from the public interface
There is a public interface available to create an view tickets: <your dolibarr URL>/public/ticket/
You can protect the public page with a Captcha. This can be enabled under Home -> Settings -> Security where you can set a switch regaring Captchas on public pages.
