Module Ticket
| Ticket | |
| Numéro/ID du module | 56000 |
| Doc développeur du module | Module Ticket (developper) |
Create a ticket from backoffice
Create a ticket from the public interface
There is a public interface available to create an view tickets: <your dolibarr URL>/public/ticket/
You can protect the public page with a Captcha. This can be enabled under Home -> Settings -> Security where you can set a switch regaring Captchas on public pages.
