Module Event Organization
This module will is used to organize Events:
An event can be a congress, a summit, a DevCamp, a forum, a training campaign, a virtual congress...
An Event is organized by defining and following tasks.
You can group a lot of existing element of an event (proposal, invoices, stocks movement, etc...).
An event is a project, with a special role.
List of parameters:
Label of tasks to create automatically when project is validated - : you can define a list of list of 'standart' task created while validating a new event.
Category to add to third-parties automatically created when someone suggests a conference : TAG automacly added to third-partie when a conference is added to the event.
Category to add to third-parties automatically created when they suggests a booth : TAG automacly added to third-partie when a booth is added to the event
In the form to create/add an attendee, restricts the list of thirdparties to thirdparties in the category : an attendee can't have those TAG
In the form to create/add an attendee, restricts the list of thirdparties to thirdparties with the nature: an attendee is limited : Not prospect, nor customer ?
Template of email to send after receiving a suggestion of a conference
Template of email to send after receiving a suggestion of a booth
Template of email to send after a registration to a booth has been paid
Template of email to send after a registration to an event has been paid
Service used for the invoice row about a booth location
Service used for the invoice row about an attendee subscription to an event
Seed to secure the key for the public registration page to suggest a conference : secured key for public page of registration
After getting on to the Home -Setup- modules, this module can be viewed under “Projects ->Organized events”.
