Module Ultimateimmo EN
Revision as of 16:56, 16 November 2021 by Eldy (talk | contribs)
Module name UltimateImmo
Editor / Editeur Atoo.Net - https://www.atoo-net.com
Last update date / Date mise à jour fiche / Fecha última actualización 2021-11-16
Prerequisit
Installation procedure
  • Download the module archive file (.zip)
  • Place the file in the root directory of dolibarr
  • Unzip the zip file using the unzip command module_ultimateimmo-X.0.0.zip
  • The correct location of the module must be of the type: htdocs/custom/ultimateimmo
  • The module is then available and can be activated
You can also use the "Deploy / Install an external module" tool from the Configuration> Modules / applications menu (available from version Dolibarr 6).
