Module Ultimateqrcode EN
Revision as of 16:25, 7 November 2021 by Grandoc (talk | contribs) (Created page with "<!-- BEGIN interlang links --> <!-- Do NOT edit this section Links below are automatically managed by PolyglotBot You can edit links on the English source page : Mod...")
Module name Ultimateqrcode
Editor / Editeur Atoo.Net - https://www.atoo-net.com
Last update date / Date mise à jour fiche / Fecha última actualización 2021-11-7
Prérequis
From the application
Manually
unzip modulefile.zip
Vous pouvez également utiliser l'outil "Déployer/Installer un module externe" depuis le menu Configuration > Modules/applications (disponible à partir de la version Dolibarr 6).
