Module Ultimateimmo EN
Module name | UltimateImmo |
Editor / Editeur | Atoo.Net - https://www.atoo-net.com |
Prerequisites / Prérequis |
Last update date / Date mise à jour fiche / Fecha última actualización | 2021-11-7 |
Note / Nota |
Prerequisit
Installation procedure
- Download the module archive file (.zip)
- Place the file in the root directory of dolibarr
- Unzip the zip file using the unzip command module_ultimateimmo-X.0.0.zip
- The correct location of the module must be of the type: htdocs/custom/ultimateimmo
- The module is then available and can be activated
You can also use the "Deploy / Install an external module" tool from the Configuration> Modules / applications menu (available from version Dolibarr 6).
