Module Ticket
Revision as of 18:17, 13 October 2021 by Bruno (talk | contribs) (link to portuguese page)
Ticket
Numéro/ID du module 56000
Doc développeur du module Module Ticket (developper)
Create a ticket from backoffice
Create a ticket from the public interface
You can protect the public page with a Captcha. This can be enabled under Home -> Settings -> Security where you can set a switch regaring Captchas on public pages.
