Inventories
Revision as of 08:14, 30 April 2021 by Hystepik (talk | contribs)
The Inventory is a feature available by default when the Module Stocks is enabled. This documentation describe how to use the inventory feature.
Initialize a new inventory
Initializing a new inventory is the first step for inventory. You can create a new inventory on the Products/Services tab, clicking Inventories on the left menu and then New Inventory.
The only requirement to create a new inventory is a reference and the other fields are optional.
Making the inventory
To make the inventory, you need at first to click on the button "Validate (start)". Next you need to change tab to "Inventory" on top next to tab "Card".
Now you must fill the column "Real Qty" in the tab for each row, to help in that task the module permit to fill real quantity by scanning object with barcodes or it permit to fill the real quantity with expected quantities.
Don't forget to click on Save button on the bottom on the page to save the changes.
Finishing an inventory
This is the step where stock movement will be recorded to update your current stock to the value your entered at the previous step. To archive this step you need to use button "Generate movements and close".
