Revision as of 12:34, 19 February 2021 by Eldy (talk | contribs) (→‎Strings)
These are some rules on language, syntax and norm we use in the Dolibarr project:
Versions
  • Dolibarr must work on:
  3. MySQL 5.1+
Copyright Norms
<?php
 * Licence information
PHP Norms
PHP
  • Dolibarr is written with PHP and supports all versions of PHP higher than 7.1.0+. All files must end with extension .php
  • Usage of PHP superglobals variables must use the dedicated operators $_COOKIES, $_SERVER, $_ENV but use the Dolibarr function GETPOST() to get the contents of $_GET or $_POST..
  • Other operators ($HTTP_SERVER_GET, ...) are now deprecated in PHP, so they must not be used. Code must work if option register_long_arrays is set to off. Moreover, the code must work when PHP option register_globals is off (recommended by PHP). It must also work if the option register_globals is on (by default on a lot of installations).
  • Do not use PHP_SELF. Use instead $_SERVER["PHP_SELF"]. Also, Dolibarr framework sanitizes content of $_SERVER["PHP_SELF"] variable (into main.inc.php file, before any business code).
  • When several variables must be initialized with the same value, you must use individual declarations (separated by ;)
$var1 = 1;
$var2 = 1;
$var3 = 1;
</sousyntaxhighlightrce>
instead of
<syntaxhighlight lang="php">
$var1 = $var2 = $var3 = 1;
which is slower.
Strings
  • Strings must be have variables outside of the quote.
print "My text show my ".$variable." !\n";
Comments
/* Bloc of comment
 * End of bloc
    // comment on one line
    print $i;
    // code
  • Coding style to use is the PSR-12 (https://www.php-fig.org/psr/psr-12/). Only rules tagged "MUST" are currently required. So note however the exceptions:
    • We allow elements of an array on same line and we do not always add a new line at end of each element.
    • Note 2: You can use the file dev/setup/codesniffer/ruleset.xml as rule file to control coding style with PHPCodeSniffer.
    • Note 3: You can use the file dev/setup/eclipse/PSR-12 [built-in].xml as rule file to setup Eclipse syntax formater.
    • Note 4: You may note that current code is not yet compliant with the PSR-12. The reason is that we must "now" follow the "MUST" rules of PSR-12, but it wasn't in the past. So feel free to change coding style to match new rules (keep in mind the 2 exceptions) if you find such cases.
SQL rules
DDL file format
create table llx_mytable
  field_one   integer,
  field_two   integer NOT NULL,
  fk_field    integer,
  field_date  datetime,
)type=innodb;
Table and fields structures
  • Structure of tables.
- import_key      varchar(32)                 that will contains the import code YYYYMMDDHHMMSS if you make mass import.
Eventually
- fk_user_creat or fk_user_author integer that is the id of user making creation
Note field:
or
  • Type of fields:
- double(24,8) for any amount
- real for a quantity
- date for a field date
Primary keys
Foreign keys
Alternative keys
Index performance
SQL Coding rules
  • Alias usage/Fields naming
Example:
For example, don't do:
but do:
but do:
  • Use $db->ifsql for SQL IF
Using Database triggers
MySQL specificities
  • Dolibarr MUST work even if MySQL option strict is active.
To activate it (required when developing on Dolibarr), add the following line into the config file of your MySQL server (my.cnf or my.ini)
sql-mode="STRICT_ALL_TABLES,ONLY_FULL_GROUP_BY,NO_ZERO_DATE,NO_AUTO_CREATE_USER,NO_ENGINE_SUBSTITUTION"
PostgreSQL specificities
Only MySQL files must be maintained. Those files are converted "on the fly" by the database Dolibarr driver.
MySQL Syntax:
PgSQL Syntax:
There is no native SQL requests "UPDATE FROM" in all Dolibarr core. But if you use one in your own code of your module, you should do :
} else {
HTML norms
Syntax rules
For example:
Skeleton code
For example:
Dates and Timezones
UTF8/ISO encoding
  • Web pages are returned and rendered into UTF8
print 239.2 - 229.3 - 9.9;
Creation of tables
Comparing version
Logs
Working directory
dol_mkdir($mymoduledir);
Patterns of code organization
  • The Domain Model
  • The Table Module
  • The Active Record
  • The Data Mapper
Design pattern for Graphic interfaces (MVC)
There are several design patterns for user interfaces (MVC, MVP, MVVM). Many confuse this design pattern with that of using a template framework. It's unrelated. A template framework (see previous point) is only linked to the "V" part of these models.
-> Dolibarr uses the MVC Design Pattern. Part M is materialized by a DAO class containing the CRUD (Create-Read-Update-Delete) methods for accessing the table. Many frameworks have chosen to put the C code part (Controller) and the V code part (View) in different files, or even separate directories. The maintenance seems easier on paper, in practice, you have to juggle constantly between a ton of files when your project become larger. In Dolibarr, the separation is made by a simple comment section. The part of code C (Controller) is therefore the code that follow the tag
 * Actions
It is followed by the part of code V (Vue), well separated from the C by the tag
 * View
This mode of separation has had a neutral effect on new developments but has made it possible to reduce the time required for maintenance and fixing bugs so significantly that it is not envisaged to switch to another type of separation (yes the findings made in real life are not always those expected by school theory). The important thing remains that there is always a separation between C and V, no matter how this separation is materialized, as long as it is (Reminder: Do not confuse the notion of separation of C and V with the notion of separation of the code to feed the data of a View and of the code to format the View, this a principle of separation relating to the Design Pattern of Vue, see next point).
Design pattern for Views - Presentation
There are frameworks that specialize in Vue Design Pattern, the part of formatting the screen seen by the user. Old versions of Dolibarr used Smarty. This framework is an overlay to an already very powerful screen formatting framework called ... PHP. The benefits being much lower than the disadvantages, it has been abandoned in favor of PHP templates (.tpl.php file) which remain the simplest, the most universal, the most scalable and the most efficient, of the presentation frameworks.
Its only flaw is that it cannot guarantee 100% the deviations of a developer who would integrate into the View, a logic unrelated to the presentation (therefore other than code intended for generation, formatting, HTML output , test or loop logic). This point is however controlled by the validation mechanism of the project managers' code.
Here again, it is the experience and the observation of a better productivity performance that has motivated the abandonment of the external Presentation frameworks in favor of the PHP framework.
