Help About Screen: Translation Setup
Menu Path: Home ► Setup ► Translation
Translation setup help you to customize translation keys to your needs. In this page you can
- Overwrite a translation string
- Search a translation key or string
To overwrite a translation string on Dolibarr you have three fields to fill :
- The language that will be overwritten
- The translation key : To find a translation key, go on the "Search a translation key or string"
- The new translation string to show
Then click on ADD button
The overwrite will be used everywhere in the application but also on the generated documents
First you need to select which language you would like to search. Click on the language selection list of the title
Then you search by Key or by translation string by filling the corresponding field.
When you have found the string you would like to overwrite, just click on the + at the end of the string line
